pullin the head
Old Mar 4, 2008 | 08:28 AM
tooblue's Avatar
tooblue
pullin the head
i have started to pull the head on the passenger side because it had a minor knock and it was puffin blue smoke, i have pulled the injection pump, the manifold, and almost have the head off. my question is what could be causing it? it didnt have any bent push rods, so maybe bent valve or flat lifter? any help is apreciated. thanks
Old Mar 4, 2008 | 09:54 AM
PLC7.3's Avatar
PLC7.3
Could have been a bad injector.............bad CDR, valve oil seal.....what did the smoke smell like......fuel, oil or coolant.
Old Mar 4, 2008 | 12:53 PM
tooblue's Avatar
tooblue
it smelt like oil. when i had the valve cover off i fired it up and it puffed blue smoke out of the pusrod hole. that why i was thinkin bent valve or stuff valve.
Old Mar 4, 2008 | 01:26 PM
f100guy's Avatar
f100guy
so you didn't do any diagnostics or search here before removing head. that's 100 bucks in gaskets to remove one head.
Old Mar 4, 2008 | 01:31 PM
PLC7.3's Avatar
PLC7.3
If your doing one side do both heads........ have them checked over for condition. You will need new head gaskets, bolts and valley pan......
Note to pull the head on pax side... you will be required to hold the push rods up to clear the A/C box ....... same going back in.
Check this out if you have not already........
https://www.ford-trucks.com/contents...urbo%20Install
Old Mar 4, 2008 | 01:38 PM
tooblue's Avatar
tooblue
why would i need new head bolts?
Old Mar 4, 2008 | 01:40 PM
f100guy's Avatar
f100guy
they stretch and won't torque down correctly. both head gaskets and the intake gasket is 150 bucks here in houston. don't know about the bolts.
Old Mar 4, 2008 | 01:43 PM
tooblue's Avatar
tooblue
im not worried with the price of gaskets. im still trying to figure out what is wrong with my truck. its worth more than 150 bucks to me.
Old Mar 4, 2008 | 01:46 PM
f100guy's Avatar
f100guy
yeah but just throwing parts on it isn't going to fix it. you gotta do some diagnostics steps on it. easiest things first.
Old Mar 4, 2008 | 01:48 PM
tooblue's Avatar
tooblue
glad you got that figured out.
f100guy's Avatar
f100guy
are the rockers tight, is it missing or just a slight knock and smoke. do you notice if the oil level is going down
Old Mar 4, 2008 | 01:51 PM
tooblue's Avatar
tooblue
all the rocker were tight. its missing with a slight knock and it burns oil bad. puffs blue smoke at idle and only get worse when the motor is reved.
Old Mar 4, 2008 | 01:55 PM
f100guy's Avatar
f100guy
have you taken any head bolts loose yet. if not, do you have a way to get a compression tester for a diesel that screws into the glowplug hole.
Old Mar 4, 2008 | 04:11 PM
tbone91's Avatar
tbone91
Have you serviced the CDR? If not, that can easily cause the blue smoke part of your problem. When you look down into the intake mainfold, is there a lot of oil residue?
I agree that the knock could be an injector. Have you been running any fuel additive?
Diesels are so high on compression that some blow-by is inevitable...
Old Mar 5, 2008 | 02:32 AM
fonefiddy's Avatar
fonefiddy
IDI bolts are NOT the torque to yeild type.
They are reusable. Allthough the ones near the exhaust manifold do get pitted.
