trans swap
Old Mar 4, 2008 | 06:33 AM
karlkye's Avatar
karlkye
trans swap
will a 4 speed out of a diesel f250 work in a 300 six pickup years are 19 82
Old Mar 4, 2008 | 07:03 AM
Handegard's Avatar
Handegard
The diesels used a different bold patter than the 300. You may be able to change the bellhousing, but someone else would have to chime in on that...
Old Mar 4, 2008 | 07:50 AM
alxsnmr's Avatar
alxsnmr
The T-18 and NP trannies should allow for a different bellhousing to be bolted to it, but the question would be is the four bolt pattern on the back of them the same b/w the two trannies. The other question is do you have 4wd? This is pertient to the transfer case patterns and if you have a circular pattern on the T-case to tranny on both then you are golden, otherwise keep lookin'.
Old Mar 4, 2008 | 06:53 PM
Mudsup's Avatar
Mudsup
The previous owner of my 83 F-100 4x2 had a 4speed from a 80 f-250 put into it but i don't know if it was a diesel or what size engine it had.
