Vacuum advance source
Old Mar 4, 2008 | 03:25 PM
cfrives3's Avatar
cfrives3
I don't know why, but I always seem to forget which is the correct source for vacuum advance. Is it carb vacuum or manifold? I was thinking it is carb.
Old Mar 4, 2008 | 03:39 PM
Piffery1's Avatar
Piffery1
Depends on the vehicle/engine. My '83 F350 with the 460 uses manifold vacuum, straight when cold and through a restrictor when warm. Many others us a special port on the carburetor. The correct vacuum routing for your vehicle should show on its vacuum diagram.
Old Mar 4, 2008 | 03:50 PM
cfrives3's Avatar
cfrives3
It is an 85 straight 6 (300). I swapped in the duraspark system, so I need a vac advance source.
Old Mar 4, 2008 | 04:26 PM
Piffery1's Avatar
Piffery1
There should be a port (ported vacuum) on the carburetor that has little or no vacuum at idle but produces good vacuum as the throttle is opened a little. That would likely work best. But, manifold vacuum would work too, little higher idle speed probably.
Old Mar 4, 2008 | 05:06 PM
cfrives3's Avatar
cfrives3
Thank you. Now it's on to keep trying to track down why there is only a spark from the coil when you let off of the key. See other post!
Old Mar 4, 2008 | 07:59 PM
beetle's Avatar
beetle
Hmmm....are you sure about straight when cold and restricted when warm? Mine came factory new just the opposite.
Old Mar 4, 2008 | 09:12 PM
Piffery1's Avatar
Piffery1
I could be wrong, the restriction is in the line going to the top port on the thermally operated valve which I thought was open to the center (vac adv) port when the engine is warm.
Waltg78's Avatar
Waltg78
I tested my vacuum advance today and i sucked on the vacuum hosed as hard as i could and no movement inside the distributor cap do i need a new vacuum advance switch?
Old Mar 4, 2008 | 09:42 PM
Piffery1's Avatar
Piffery1
Waltg78, If it was the hose going directly to the advance unit then I'd say yes. Especially if you could continually suck air. But first try to move the advance mechanism by hand just to see if it's binding or broken.
