I am new to the forum and was trying to retrieve my code from my 2002x, and betwwen my wife and myself we have locked both keys in the truck, can someone e-mail me the list of codes for my year? briand@uniqueturf.com
In case you didn't know...your truck should have a sticker buried with the factory pre-set code on it...once you have that code...you can set your own thru the steps in the owners manual...
The only truble with setting your own code is if you disconect the battery the code will revert back to the factory setting.
I'm not 100% sure...but I've not had that happen on my '05...I will check it today though as I disconnected my battery this weekend after I cleaned my MAF sensor...
I just checked with Ford. Some models loose there codes and some don't. I wonder what lame Ford engineer thought this one up. So I am right and wrong at the same time. Whoes to say.
