will changing torque converter help?
Old Mar 3, 2008 | 07:05 PM
jdphillips73's Avatar
jdphillips73
1994 302/4r0w7 tranny, 3.55 gears...
using it to tow 4500 camper, I know that I will upgrade to 4.10.
My tranny seems like it is gonna fail if i pull the camper as is.. I have read about these "towing torque converters" that are supposed to help. Seems like my torque converter just spins and spins without the truck moving much, and forget about a hill...
I changed the fluid in the tranny and it looked good, magnet clean, no garbage in pan... tranny has dreaded torque converter shudder... Im thinking of changing the valve body on that... any ideas? OR, is there a tranny that I can just bolt in that wont require computer adjustments or linkage or driveshaft issues... Im looking for a tougher more dependable tranny
Old Mar 3, 2008 | 07:09 PM
andym's Avatar
andym
You really don't have the ideal truck for towing. The tranny isn't weak exactly, but it's not real strong either. I wouldn't tow that much weight without a shift kit and a cooler for it. If it's shuddering, then it sounds like it's on its last legs anyway.
The 302 is not a great towing motor either. It doesn't make the low end torque that a 300 or 351 will.
Old Mar 3, 2008 | 07:12 PM
jdphillips73
I have a cooler installed with temp gauge
Old Mar 3, 2008 | 07:24 PM
quicklook2's Avatar
quicklook2
did you drain the torque convertor when you changed the fluid?
Old Mar 4, 2008 | 07:18 AM
jdphillips73
yes, i drained it. My original question was "do these companies offering towing torque converters or performance converters do anything that would benefit towing..
Old Mar 4, 2008 | 07:37 AM
Conanski's Avatar
Conanski
Performance TQ converters are designed to never lockup, which may help keep the motor in it's powerband but will generate hugh amounts of heat and that's murder on transmissions. Your best plan of attack is to get the 4.10 gears and at least have a shift kit installed in the tranny if you don't also go ahead and get a new stock style TQ converter, and then keep it out of OD when towing. Even with all this it won't be like you are suddenly driving a Powerstroke, but it'll have a chance of living to tell the story.
Old Mar 4, 2008 | 07:45 AM
jdphillips73
Thanks for the reply.
My other question was.. is there a trans that is stouter that would bolt up in the truck that wouldnt require work on computer, changing linkage, or driveshaft issues. (see original post for truck info)
Old Mar 4, 2008 | 07:50 AM
jroehl's Avatar
jroehl
No. Any other tranny you put in there would require messing with all of those things.
Jason
