1978 - 1996 Big Bronco
Rear window
Old Mar 3, 2008 | 06:33 PM
DadzzTazzDullie's Avatar
DadzzTazzDullie
Question Rear window
It there and easy way to remove the rear window, the motor works on mine but will not go up & down. The drivers window is the same way, both broke within days of each other. I forgot, it's a 1993 Bronco with 351 & auto trans, XLT model.
Thanks
Terry
Old Mar 3, 2008 | 06:49 PM
andym's Avatar
andym
Hopefully the window is in the down position. It makes it easier to get to the bolts.
Either way, remove the access panel in the tailgate. There are two arms coming out of the regulator, and each arm is attached to a track. Each track has two bolts holding it to the window. Remove the bolts and the window will move freely of the regulator.
Then you have the window out of the way. Pull it out and support it with something. Once you have it up and supported you can get to the regulator and the window motor. Mine did this recently too, the plastic gear (why Ford, why?) was shattered and in pieces. Bought a new motor and it's been working great. I also shorted the "tailgate closed" switch so the window will operate regardless of whether the tailgate is open or closed.
Old Mar 3, 2008 | 07:01 PM
nanatothesixth's Avatar
nanatothesixth
rear window
ther is a person on e bay who sells a kit, it consists of neopreme round spacers, that is what usually goes, i replaced mine with that kit for lik $4.00, me gear was fine, it was just the spacers took a crap,the spacers hold the gear against the track.
Old Mar 3, 2008 | 11:22 PM
blue beast's Avatar
blue beast
You can make your own with some wood dowel rod and some rubber hose to go over
the dowel. It makes for a bulletproof spacer and it still functions like it should.
Don't pay to buy the deal on ebay or the parts house, Make your own I am sure you
can search for pictures and instructions but it is self explanatory if you take the gear
apart and measure it all and head to Homeless Depot!!
