c6-460
Old Mar 3, 2008 | 11:35 AM
badblueoval4life's Avatar
badblueoval4life
c6-460
having trouble getting my c6 torque converter in far enough when i bolt up bellhousing it binds up the motor cant turn it over any one with any ideas to make this easier???? thanks
Old Mar 3, 2008 | 11:40 AM
buffalobob's Avatar
buffalobob
ck the snout on the engine side of tc - is it a match to crank ?....large snout in a small crank ....or you didnt seat the tc in the tranny - have to turn it and push gently to completely seat it
Old Mar 3, 2008 | 01:37 PM
Handegard's Avatar
Handegard
I don't know if a C6 is the same, but I screwed up a C4 once by putting the input shaft in backwards. Turns out, both ends of the shaft fit into the transmission, but only one fits into the TC. Once I tightened everthing, the engine was seized, and the shaft was VERY stuck in the tranny...
Old Mar 3, 2008 | 02:15 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
Keep spinning the tc while you push it in. Some times you have to lift up on it while you do all that. Basically you have to line up the 2 sets of splines plus the cogs on the tc so theres 3 things to engage. If that makes sense.
