How much do you spend on Maintance?
Feb 7, 2004 | 12:50 AM
Oil, oil filters, air filters and fuel filters. And how often on each.
Thanks Stampede
Feb 7, 2004 | 07:43 AM
For me, oil & grease every 5k miles. The cost is $50. Fuel filters cost me $100 and are replaced every 15k miles. AT filter/fluid is around $200 bucks and is replaced every 30k miles. Coolant and air filter are also 30k miles and are around $130 together.
So, the cost every 5k miles is
$50 + $100/3 + $330/6 or $165 every 5k miles.
That is around $3300 in 100k miles.
Maintenance on a gasser is cheaper. Don't let anybody tell you different.
Feb 7, 2004 | 08:27 AM
Feb 7, 2004 | 08:45 AM
Mobil 1 Oil Change, 'bout $46 to $50 every 3,000 depending on where I can find enough oil.
Fuel filter, $12 @ NAPA, every 20,000.
Mobil 1 Tranny fluid cost me $130 (every 30,000), but I've got about 5 quarts sitting un-used in my garage. Tranny filter was $18 at the dealership.
Haven't changed coolant yet, but it's coming up in another 10k miles (changing it every 50k miles). Figure it'll cost anywhere from $50 to $100...
So you're looking at $2325 over 100,000 miles. BTW, I highballed all my numbers.
So, $11625.50 every 50k, $69.75 every 3k, or 0.02325¢ per mile!!
Feb 7, 2004 | 08:51 AM
Feb 7, 2004 | 10:18 AM
Every 3 months: 5w30 Mobil 1 (6qts) $30 Purolator oil filter $6.
Every year: Air filter: $19, Fuel Filter: $10
Every 2 years: Mobil 1 Syn ATF (6 qts for manual trans) $45, Antifreeze: 4 gallons Motorcraft Gold $75, 3 gallons distilled water $5. Wiper blades: $12
Every 5 years: Serpentine belt: $28, Thermostat (180*) $12, Radiator hoses: $80, Recovery tank, heater and oil cooler hoses: $60. Spark plugs: $90 (8 platinum), 800 amp battery: $100, 4 265/75R16E tires: $750. Brake pads and supplies: $130, Brake fluid $26 (4 qts.) 4 shocks $280 (Bilstein) Power steering fluid: $20 (5 qts).
At 100,000 miles/ 7 years: Rear diff LS Motorcraft XL3 friction mod: $9 (8 oz.) Motorcraft 70W140 syn gear oil: $20 (1 gallon)
About $3296 for 100,000 miles for everything
About $1211 just for motor oil, oil filter, fuel filter and air filter alone.
Feb 7, 2004 | 10:38 AM
"So, $11625.50 every 50k, $69.75 every 3k, or 0.02325¢ per mile!!"
Damn Munkey, I hope there is an extra "1" in your $11625 figure!
Feb 7, 2004 | 11:27 AM
It's the motor oil I use, it's all natural lubricant, made from yakberries, squeezed from under the armpits of Tibetian monks, every time Jupiter and Pluto are in alignment with Io.
And if you think it costs a pretty penny to get this kind of motor oil, just think how hard it is to obtain enough yakberries (guess where the berries are found on the yak
) for 6 1/2 quarts of it!
Good eye for the extra 1 though!
Feb 7, 2004 | 04:02 PM
oil & filter every 5K: $15
tranny service & rear gear oil @ 60K: $165
Knowing I've done the work myself with quality parts: Priceless !!
Stampede
Jul 14, 2004 07:56 PM
Stampede
Feb 24, 2004 08:19 PM
Stampede
Sep 30, 2003 05:28 AM
Stampede
Sep 30, 2003 05:25 AM
Stampede
1997 - 2003 F150
Jun 8, 2003 07:12 PM
