Wicked Wheel Installed
Old Mar 3, 2008 | 07:33 AM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Finally got it in. Only took me 6 hours to get the turbo out (haha god that was h*&% ) Anyway, it screams like no other! I owe you guys the world i would never have tackled this job alone. I recommend this mod for everyone.
Old Mar 3, 2008 | 08:05 AM
randomhero1172's Avatar
randomhero1172
As soon as the weather warms up ill be doing it. i got the wheel sitting in my room. Congrats man!
Old Mar 3, 2008 | 08:15 AM
STROKIN'IT7.3
i'll tell you one thing, on the up-pipes, WD-40 is your best friend especially if the turbo has never been out. All in all, its not hard just frustrating so don't lose your cool. (O and do the foil delete while you got it if you havent already; it makes a world of difference)
Old Mar 3, 2008 | 10:04 AM
MTDewX's Avatar
MTDewX
Foil delete is just for SOund right? can't imagine it actually helping. unless it lets the air cool or some thing?
Old Mar 3, 2008 | 10:21 AM
DR JOE's Avatar
DR JOE
Congrates on your new install... That is something I can't wait to do...
So what is the advantage of deleting the foil??? Other than you can paint your pipes a cool color???
Doc.
Old Mar 3, 2008 | 10:52 AM
Smokin''s Avatar
Smokin'
Smokin
It makes your turbo more audible, which results in a terrible case of the perma-grins.
Old Mar 3, 2008 | 11:21 AM
DR JOE's Avatar
DR JOE
BAHAHAHAHAHA...... Got it....
Doc.
Old Mar 3, 2008 | 03:59 PM
SVLERF250PWRSTRKE's Avatar
SVLERF250PWRSTRKE
I know the foil itself makes a awesome difference, but does the wicked wheel add that much scream?
Old Mar 3, 2008 | 04:05 PM
Smokin''s Avatar
Smokin'
Smokin
Yes! See this video, posted by member Powestrokedlariat a few days ago. His truck has a WW. 4" turbo back helps too.
https://www.ford-trucks.com/lc/lc.ph...eature%3Demail
You should hear the noise from INSIDE a truck that's had this done.
Old Mar 3, 2008 | 04:07 PM
randomhero1172
Ya my truck has 281,000 and the turbo hasnt been off in ...Well not anytime i can remember. I plan on stocking up on some PB and WD-40! and not to mention some cold ones!
Old Mar 3, 2008 | 04:15 PM
racincowboy's Avatar
racincowboy
Forgive my ignorance but what is a wicked wheel? I see that it is something that mounts on the turbo its self? I have a 99psd dually with 4 in straight pipe from the turbo back and it sounds just like that one in the you tube video. It gets quite a bit of attention pulling hills with a good load on.
Old Mar 3, 2008 | 04:24 PM
Smokin''s Avatar
Smokin'
Smokin
Look here: http://www.dieselsite.com/index.asp?...PROD&ProdID=47
If your truck is an early '99, it has a wicked wheel from the factory.
Old Mar 3, 2008 | 05:13 PM
racincowboy
What is the cut off date that tells you if it was an early 99 or a later one? My mfg date was 7/98.
Old Mar 3, 2008 | 05:18 PM
Smokin''s Avatar
Smokin'
Smokin
Yes, you have an early '99.
Old Mar 3, 2008 | 06:41 PM
racincowboy
if I have one from the factory why do I still get that surge at high boost pressures pulling heavy loads. I have a 12k 5th wheel that I pull and it will surge do you think replacing the wicked wheel take care of that issue? thanks for all the help glad I found this site you guys definately are ford guru's
