body lift
Old Mar 3, 2008 | 07:24 AM
1983FORD's Avatar
1983FORD
body lift
im looking to buy a 3 inch body lift for my 83
its just blocks and bolts.
im goin to buy bumper brackets later
my question is what all will need to be adjusted and lifted to make it all work.?
Old Mar 3, 2008 | 09:08 AM
Sycostang67's Avatar
Sycostang67
Anything that crosses from the body to the frame will be affected, the linkages for the tranny, fuel filler hose, steering column, I imagine the brake lines and radiator hoses will have some play in them, but make sure they dont get kinked.
Old Mar 4, 2008 | 12:02 AM
blue beast's Avatar
blue beast
Don't waste your money!! Buy helper springs for the rear(not blocks) and either longer
springs and camber adjusters or if you are going big dro brackets. Sure body lifts will
let you clear bigger tires but will not help you to clear trail obstacles!!
http://broncograveyard.com/bronco/c-..._lift_kits.htm
http://broncograveyard.com/bronco/i-...eafs__rear.htm
Old Mar 4, 2008 | 05:24 AM
uncle.stosh's Avatar
uncle.stosh
Don't do it.
Lift the suspension instead.
Old Mar 4, 2008 | 07:03 AM
1983FORD's Avatar
1983FORD
the suspension is already lifted.
i just want bigger tires
Old Mar 4, 2008 | 10:36 AM
Franklin2's Avatar
Franklin2
It messes your fan shroud up too. You have to move it down or cut the bottom out of it.
Old Mar 4, 2008 | 11:25 AM
blue beast's Avatar
blue beast
Check your local laws since bumper/ lights height is usually the place where they
measure to see if you are legal. Make sure it is going to measure out before doing
it. Your other option is to cut out the fenders and use some fender flares to give a
finished look.
Old Mar 4, 2008 | 04:27 PM
uncle.stosh
What size tires do you want to run?
Old Mar 6, 2008 | 08:58 AM
td2's Avatar
td2
installed one on my 86 to get enough room for some 38.5 swampers i love it
Old Mar 6, 2008 | 01:51 PM
1983FORD's Avatar
1983FORD
did you body lift it yourself?
was it hard?
Old Mar 6, 2008 | 02:03 PM
td2's Avatar
td2
my wife and i did mine on a weekend the only really hard part was getting all those rusty bolts loose. i had a welder friend of mine build the front bumper bracket for me and i haven't raised the back one yet. the shop here wanted $150 to install it all in all i would do it again if i had to. it's a pretty good job and my helper does not do much other than hand me tools. hopr this helps and good luck
Old Mar 6, 2008 | 02:35 PM
1983FORD's Avatar
1983FORD
yeah it does..
how did yuo get the cab off the frame?
Old Mar 6, 2008 | 02:50 PM
dopeys4x4's Avatar
dopeys4x4
build a A frame stand is the easiest way or u can get some friends an lift it then put some 4x4 boards under it
Old Mar 6, 2008 | 04:36 PM
uncle.stosh
Not trying go be a smarta$$ or anything, but 38.5's on a stock TTB is just asking for trouble. Unless it's just a mall cruiser.
That would be a shame.
Old Mar 6, 2008 | 05:22 PM
dopeys4x4's Avatar
dopeys4x4
i agree wit uncle
