Here's the description of the motor would you guys have any ideas on the output?
early 70's Ford 351 Cleveland engine.2 bolt Block has been hot tanked,magnafluxed,bored true and honed with a torque plate.The crank was ground .010-.010,polished and deburred,rods shotpeened,SPS bolts and resized.TRW forged pistons (.030)over,rotating assembly ballanced,Clevite 77 bearings,Speed Pro moly rings.Four barrel closed chamber heads (60cc)(10.7 to 1)comperssion ratio,2.250 intake and 1.710 exhaust Mildon stainless valves,springs to match cam,Moly retainers and locks,7/16 studs,Manley guide plates,chrome moly push rods,Cam Dynamics roller rockers(1.7) ,Comp Cams solid cam and lifters(2825)dur at .050, 236/236 lift .570/.570 ,110 cs .Cloyes chain,Edelbrock Performer 351-4v intake,Accel dual point dist,Weiand aluminum water pump.Melling oil pump
What would a motor like this cost to build, a guy is selling this motor for about 2000, I know that he put more than that into it. Oh i posted a question about the output and some one said it would be around 474hp and 442 ftlbs. And that was with a holley 750 double pumper carb.
