HELP...can someone desktop dyno my engine?
Old Mar 27, 2002 | 09:15 AM
teamwizard's Avatar
teamwizard
Post HELP...can someone desktop dyno my engine?
[updated:LAST EDITED ON 27-Mar-02 AT 10:19 AM (EST)]hi guys, if it wouldnt be too much trouble i would love if someone would input this on there desktop dyno. this is what i plan on doing--
(Note: the truck has no emmissions stuff on it)
400ci
9.0:1 Dynagear pistons bored .030 over
Melling oil pump
Edelbrock timing chain
rebuilt stock 2v heads
Edelbrock Per. 400 intake, without egr
Holley 600 carb
Edelbrock Victor series water pump
Crane Powermax lifters
Crane Powermax dual patterned cam (can u try both of these im not sure which one)
Duration@.050--204/214 Gr. lift .493"/.502" RPM 1500-4500
Duration@.050--216/228 Gr. lift .524"/.519" RPM 2000-5000
im open to suggestions on what i should do, so any input is greatly appreciated
thank you so much in advance
Gabriel
Old Mar 27, 2002 | 11:23 AM
Fastcat's Avatar
Fastcat
I'm new to Desk Top Dyno so I might be off. But if you use stock exhaust manifolds it cam out to just under 300 HP and about 360 ft lbs of torque. If you add header it cam out to 350 HP 400 ft lbs of torque. Hopefully someone with a little more practice at this will give you another answeer.
Old Mar 27, 2002 | 01:10 PM
teamwizard's Avatar
teamwizard
fastcat, thanx for your reply. i do have headers, sorry i forgot to say that! im wondering which cam u used to get those numbers. and also can u give me at what rpm those numbers where reached?
thanx gabriel
Old Mar 27, 2002 | 07:38 PM
Fastcat's Avatar
Fastcat
The torque peak was at 4000 rpm.The torque line started at about 370 and went up to 400 then dropped off after that. The HP peak was at about 5200 rpm.
Old Mar 27, 2002 | 08:07 PM
gregdatech's Avatar
gregdatech
[updated:LAST EDITED ON 27-Mar-02 AT 09:07 PM (EST)]Someone tell me where I can get desktop dyno and how much is it?
Old Mar 27, 2002 | 09:21 PM
teamwizard's Avatar
teamwizard
if anyone else out there has a desktop dyno. can u please run my info through so that i can get a second opinion! thanx for your help fastcat.
gabe
Old Mar 28, 2002 | 09:56 AM
Fastcat's Avatar
Fastcat
I did a search for it and got the name of the company that sales it that way. It cost me $44. Now I just need to print off and read the manual.
Old Mar 28, 2002 | 04:48 PM
beartracks's Avatar
beartracks
Old Mar 28, 2002 | 06:21 PM
shazam's Avatar
shazam
OK I will run it for you but I need more info .
Head mods if any,Valve sizes
open chamber or closed chamber heads
As for the cam I need the timing numbers
Look on your cam card for these.
IVO IVC EVO EVC
Is the carb a Vacume type or Double Pumper.
Headers to daul exhaust or single
Single plane or dual plane intake
That 9.0 to 1 is this guestamate or actual
Old Mar 28, 2002 | 10:34 PM
teamwizard's Avatar
teamwizard
shazam thank you in advance for running my info thru the dyno. i dont know if i will be able to answer your question but here goes...
***stock 2v heads
***open chamber or closed chamber heads--(open i think, whatever 351m/400 heads are!)
***as for the cam timing numbers i still do not have the cam...but i plan on getting the crane powermax with the 204 duration. if u really need the timing, i will call summit.
***carb--holley 4 barrel 600cfm vacuum
***Headers to true dual exhaust
***intake is dual plane
***9:1 compression is what my pistons will have, i guess its not 100% sure. so i guess its a guesstamate. i would like to have about 9.2:1....but for now just do it with 9:1
if this info isnt enough, or u have any advice on anything please write me at TeamWizardL7(No Email Addresses In Posts!)
thanx gabriel
Old Mar 29, 2002 | 11:47 PM
teamwizard's Avatar
teamwizard
if no one else can desktop dyno this for me, can ya'll tell me where i can buy the program. does best buy sell it?
gabriel
Old Mar 30, 2002 | 08:48 AM
shazam's Avatar
shazam
[updated:LAST EDITED ON 30-Mar-02 AT 09:56 AM (EST)]Well if you look in your Jeg's catalog they have it in there page 128
Part number #720-3626 $39.99
And I'll get it run on my dyno for ya
Old Mar 30, 2002 | 09:39 AM
shazam's Avatar
shazam
OK Here's what I come up with .
331 Hp @4500 Rpm
432 Tq @2500 Rpm
Its a Stump puller at low rpm's anything over 4500 Rpm's and it goes down hill fast.
Just the right set-up for Mudding and off-roading with BIG tires.
Old Mar 30, 2002 | 11:29 AM
Double_Agent's Avatar
Double_Agent
Shazam, would you mind running my engine specs through your DeskTop Dyno? I would really appreciate it very much. My specs are on this post.
https://www.ford-trucks.com/dcforum/DCForumID12/718.html
Thanks again,
Kevin (Double Agent)
Old Mar 30, 2002 | 07:23 PM
GT40man's Avatar
GT40man
double agent, what type of heads, valve sizes and any porting? this will be needed.
