Need Help Diagnosing 351W FI Engine Problem
Old Mar 2, 2008 | 09:00 PM
E460's Avatar
E460
I recently bought a totaled 95 Bronco for the engine. After much torching and metal sawing, I finally have it out of the mangled Bronco body and on my engine stand. My problem is it is locking up when I rotate it, on the #1 cylinder. It comes to a solid stop at about 5 degrees before TDC and when I back it up, it dead stops at about 5 degrees after TDC. It acts like it has something in the #1 cylinder. Could it have rotated enough after hitting a tree to "swallow" something? The wreck destroyed the oil pan, so I have it off to change it, but can see nothing in the lower end to lock it up.
All suggestions are welcomed.
Thanks.
Old Mar 2, 2008 | 09:39 PM
Animalistic's Avatar
Animalistic
If it was under any power when it was wrecked, and the engine came to a complete quick stop, then there is a good chance that a connecting rod or wrist pin broke. Could have also jumped time and the valves are hitting the pistons. I would pull the timing cover and check the gears and marks. It beats pulling the heads. Good luck.
Old Mar 3, 2008 | 09:03 PM
86caprirs's Avatar
86caprirs
I think you will be doing a tear down to check it out.
