Transfer case question.
Old Mar 2, 2008 | 08:42 PM
savagefan's Avatar
savagefan
Embarassing to admit but I don't know where to check the oil on my T-case. It's a 91 Exploder automatic. A little help? Thanx.
Old Mar 2, 2008 | 10:13 PM
mrshorty's Avatar
mrshorty
On the back of the transfer case (you may have to remove the vibration dampener weight) is a fill plug. Remove the fill plug and stick your finger in. If you get fluid on your finger, it's full (fluid level should be about even with the bottom of the fill plug hole). If the fluid is dark brown or black, it probably is due a change. If it smells like gear lube, someone has put the wrong fluid in there (requires ATF).
Old Mar 2, 2008 | 10:37 PM
aquanaut20's Avatar
aquanaut20
Make sure you can remove the top plug(fill) before removing bottom plug (drain)
Old Mar 3, 2008 | 07:37 PM
savagefan's Avatar
savagefan
Thanx very much.
