2002 Ford explorer door locks
Old Jan 19, 2008 | 05:34 PM
texasgoat's Avatar
texasgoat
How do you remove the door panel to get to the door lock cylinder. Door will not lock with remote. It will unlock after manual locking. Thanks Jim
Old Jan 19, 2008 | 06:53 PM
rrgone's Avatar
rrgone
Pry the trim piece around the door handle off. Pry the piece with the window switches off. Disconnect the window switch connectors. Remove one screw in there where the switch was and two screws at the bottom of the door panel. Pull UP (not out) on panel and armrest.
Seems odd that the doorlock actuator works in one direction but not the other. You can try spraying it good with WD40 or something but it might be bad. Good luck.
Old Jan 19, 2008 | 08:17 PM
winfordr's Avatar
winfordr
Removing the door panel is much more difficult than replacing the actuator, once you have the panel off. See post below, generic actuators are cheap. I would prefer to do it once and done.
Old Mar 3, 2008 | 08:33 PM
w9jbc's Avatar
w9jbc
Hi anyone ever discovered a drawing or picture detailing the linkage on the lock cylinder mine has shucked a plastic lever off the cylynder and i managed to procure another part but cant determine how it is supposed to go together again short of tearing the other door apart thanks jim
newfordy
Paint & Bodywork
Jan 8, 2015 09:02 PM
jimandnena
Aug 10, 2014 09:46 AM
Jim Kronenberger
Jun 25, 2014 03:00 PM
mossy500
1997 - 2003 F150
Apr 6, 2014 11:13 PM
jdb8805
Jul 31, 2002 03:02 PM
