Wiring Harness/ECM sweap question
Old Mar 2, 2008 | 07:44 PM
Grey89F250's Avatar
Grey89F250
Ok so I got the the air handler for the 92 dash today from the local pick and pull and while I was pulling it out I had one last great idea! Swap the whole wiring harness and ecm. Then I could use the late model gauge cluster. How hard do you think this would be? What is different from and 89 4.9 to a 94 4.9? Just another one of my crazy ideas. Tell me what you think.
Old Mar 2, 2008 | 09:01 PM
country0001's Avatar
country0001
Talking
Depends on if you have the same tranny. Otherwise, it couldn't hurt to try?
Old Mar 3, 2008 | 10:04 AM
Grey89F250's Avatar
Grey89F250
I didnt think about that. The one I was thinking of getting it from has an auto in it. Im assuming it wont work with my ZF-5.
Old Mar 3, 2008 | 11:38 AM
Grey89F250's Avatar
Grey89F250
Will my ECM plug into a 92-96 wiring harness?
Old Mar 3, 2008 | 04:10 PM
andym's Avatar
andym
Sort of. But no sense in swapping the ECM unless you have a reason to.
Also, the wiring harness and ECM changed dramatically in 1996 for the F-150 because it went to OBD-II. It also changed in 94 or 95 to accommodate mass air. Be careful.
An automatic ECM will work fine in a vehicle with a manual, it will just set a couple of codes because the tranny isn't there. It won't set the light off.
Old Mar 4, 2008 | 07:19 AM
Grey89F250's Avatar
Grey89F250
I think I have decided against this idea for now. I just got orders to Hawaii and I will be there for about 2-3 years! So I need to get this thing back on the road fast!! I may be taking it and I may not!
