Sponsored by: Real Truck
UpFitter Switched
Old Mar 1, 2008 | 07:11 PM
Sarge261's Avatar
Sarge261
UpFitter Switched
I called my dealer today looking for an upfitter switch kitfor my 06. They told me that I could not add it if it didnt come with it. I was looking on Ebay for the switches and there was a set on there for 139.00. Before I push the buy it now button I have 3 qestions...
1.) Can they be added without any modifications?
2.) Is that a good price or is there a FTE sposor that sells them? Supposedly this auction was for the fuse block that goes with the switches.
3.) Is this a plug and play install or is this a big project?
Thanks,
Sarge
Old Mar 1, 2008 | 07:12 PM
Sarge261's Avatar
Sarge261
I forgot to tell you that I do already have the Tow Command System in the truck.
Sarge
Old Mar 1, 2008 | 08:29 PM
Benchwrench's Avatar
Benchwrench
sure you can add the switches. You'll only loose the cubby but gain the switches.
The dealer is confused, what can't be added is what you already have. the tow command center.
As far as the cost, the 139 is mostlikely what OEM's are going to cost from a distributor and not a private party.
Old Mar 1, 2008 | 09:07 PM
stevestroke01's Avatar
stevestroke01
Thanks,
Sarge
Hey Sarge try this link http://catalog.powerstrokeshop.com/p...&siteid=214083 . They are real good people to deal with to.
Old Mar 1, 2008 | 11:39 PM
rotun's Avatar
rotun
Reads ***** rules!
There is a TSB on this, if I had the exact number I would be able to scan and send to you (QASIS is down so I can't look it up). Fu@king dealers!
Upfitter switch assy. PN 5C3Z13D730AAA, price is $39.45
Wiring Harness Assy. For Upfitter switches P.N. 5C3Z14A303AA for $18.75
Old Mar 1, 2008 | 11:58 PM
WilliesSD250's Avatar
WilliesSD250
Your dealer is blowing smoke up your six. You most certainly can add the upfitter switches to your truck. I know because I did. I bought my assembly from Ed back when he was still with Y2k Ford. It's a fairly easy install. My fist use of the switches was to use the number 4 switch for my high idle/charge protect.
Old Mar 2, 2008 | 12:01 AM
rollerstud98's Avatar
rollerstud98
You can also add the tow command apparently, just requires the master cylinder to be replaced and have your dealer reprogram the truck to include the tbc. pretty sure i was looking at the same switches as you and that seller also has the brake controller, it will not work on the 03 or 04 models though is what the seller told me
Old Mar 2, 2008 | 11:50 AM
rotun's Avatar
rotun
Reads ***** rules!
O.k. OASIS is done with maint. I was wrong about ther being a TSB for this, it's actually a SSM....take this to your dealer and stick it up his....nevermind.
19360 2005-2007 F-SUPER DUTY - INSTALLATION OF UPFITTER SWITCHES ON TRUCKS NOT ORIGINALLY EQUIPPED FROM THE FACTORY
TO INSTALL THE UPFITTER SWITCHES ON A 2005-2007 F-SUPER DUTY, THAT WAS NOT ORIGINALLY EQUIPPED FROM THE FACTORY, ORDER 5C3Z-14A303-AA (WIRE ASY), 5C3Z- 13D730-AAA (SWITCH ASY), AND 5C3Z-2513546-CAA (BOX - UTILITY - LESS HOUSING). THE WIRING HARNESS BOLTS ON, AND THE SWITCH PLUGS INTO IT. THE UTILITY BOX IS ONLY NEEDED IF THE TRUCK IS NOT EQUIPPED WITH A TRAILER BRAKE CONTROLLER. IT MAY BE NECESSARY TO REMOVE THE INSTRUMENT PANEL TO INSTALL THE HARNESS FROM THE BULKHEAD SIDE. REFERENCE Q-117 WHICH CAN BE FOUND AT HTTPS://WWW.FLEET.FORD.COM/TRUCKBBAS/TOPICS/QVMP.HTML FOR ADDITIONAL INFORMATION IF NEEDED.
EFFECTIVE DATE: 09/08/2006
Old Mar 2, 2008 | 01:25 PM
Sarge261's Avatar
Sarge261
SteveStroke01,
I will order them through the link you gave me. They are $40.00 cheaper there. Also I am going to assume that the first 2 switches have a relay for larger draw items. I have a BD Exhaust brake on my truck and would like to use one of the Upfitter swithces for that so I can get my power pedals back. Also could you tell me where to look for the charger protect install. Thanks for all the help and saving me 40.00. I kinnda knew my dealer was full 'o' poopie anyway. I remeber reading about this install back in 04 when I bought my 1st. Diesel. Just that it was an 04 and I couldnt do it.
Thanks,
Sarge
Old Mar 2, 2008 | 01:35 PM
mhoefer's Avatar
mhoefer
Youre sig shows a F150, but you are talking an SD right?
Old Mar 2, 2008 | 01:37 PM
Sarge261's Avatar
Sarge261
yeah I havent edited it yet. I just picked it up on Thursday. I'll fiax it right now.
Thanks,
Sarge
Old Mar 2, 2008 | 01:50 PM
mhoefer's Avatar
mhoefer
Its running all these mods when you bought it? Or are you just doing them all yourself. Does the exhaust brake work well and does it use a TC lock up controller?
Old Mar 2, 2008 | 06:51 PM
Sarge261's Avatar
Sarge261
Yes it came with all the mods, and it does have the TC lock up control from BD diesel also. The guy who had it trades every 2 years he drives about 26,000 miles a yearand does all the mods to them when he gets them. It also has the high ram intake and bigger intercooler pipe as well. The dealer insalled all the add ons when he bought it after about 10,000 miles so they will work onit without m having to return back to stock.This is the first time I have delt with this dealership and they have ben a rel pleasure so far. Latham Ford in New York. I had a bad experience with an 04 6.0 that was bought back. Ever since the day they took that truck back I always wanted another one. I was going to get an 08...but I didnt have the $$ for a 350 CC Lariat. So I saw this one on the lot. This forum did an Oasis for me it came back clean with 1 repair.The delaer gae me all the Maint. records for the truck so the price was right they gave me 25,000 for my F-150 and I bought it. It also has the deep sump trans, and rear diff covers by magtec too. Over all I am glad to be back in a Diesel...even though the prices are around $ 4.00 a gallon.
Are the parts in the link above OEM Ford parts or are they used parts. The description reads "our parts" They look new but I want to be sure before I buy
Thanks,
Sarge
Old Mar 2, 2008 | 07:38 PM
WildWildWest's Avatar
WildWildWest
Thanks,
Sarge
If you are referring to the parts from the link to powerstrokeshop.com for the upfitter switches, yes they are all original OEM brand spanking new ford parts - that is where I got mine from and it took about an hour to install. Great option for the '05 and up trucks that plugs right in.
Old Mar 2, 2008 | 08:20 PM
Sarge261's Avatar
Sarge261
Thanks WildWildWest,
Thats the answer I am looking for. I am going to oreder them 1st. thin in the a.m so they will go out tomarrow.
Thanks,
Sarge
P.S. Any Pointers on the instaall or are they pretty much straight foreward?
