Vac Lines Routing
Old May 1, 2002 | 09:00 AM
dsc's Avatar
dsc
Vac Lines Routing
Modified my 351m with all types of goodies. I am a little confused on the intallation of the vac lines. There is now a Edelbrock Pro 400 with a Edelbrock 1406 650cfm. Here is what I need.
MSD dist to manifold vac or vac on bottom of carb.There are two ports on the 650, straight vac or controlled. which one?
On the front of the 650, 1406 there is a large vac port were does this go to?
Power brakes. I am assuming vac port on manifold.
C6 modulator. ???
PVC?? This is a 1979 351M. Did it come with a PVC? The old valve cover had a plastic insert not a PVC. Looked like a vent.
Thanks Art
Old May 1, 2002 | 09:36 PM
shazam's Avatar
shazam
Vac Lines Routing
