Sponsored by: Real Truck
shift points
Old Mar 1, 2008 | 03:53 PM
shaun6z49110's Avatar
shaun6z49110
shift points
I have a 01 superduty 7.3. I put the edge juice with attitude and the evelution programer on it. It has great power but the shift points arnt right. Is there a trans programer that I could that is compatible with the edge upgrads I alredy have on the truck. Or is there a whole new way to get the trans up to speed with the engine without buying an upgrade trans
Old Mar 1, 2008 | 05:32 PM
Izzy351's Avatar
Izzy351
Shaun,
The best place for this is the 7.3 forum (https://www.ford-trucks.com/forums/forum31/) but I will tell you the EDGE is no good for the 7.3's shifting. You might try putting in a shift kit or a custom accumulator valve body. Some other chips/tuners like DP change the tranny feel quite a bit, so you're likely to hear "Ditch the Edge and go DP" quite often. The best bet is to do the kit or VB *AND* custom tuning as well as some extra cooling to help it last as long as possible.
