Brake Control Mounting
Old Mar 1, 2008 | 10:55 AM
superduty4x4's Avatar
superduty4x4
Where have you guys been mounting your trailer brake control? There aren't any really good spots to keep it out of the way that I can see. The PO of my truck put it in the cubby hole in the dash with sticky tape and it drives me crazy having it like that.
Old Mar 1, 2008 | 11:11 AM
rbaker6336's Avatar
rbaker6336
below cubby on bottom of dash
Old Mar 1, 2008 | 11:43 AM
pbr man's Avatar
pbr man
I had mine mounted on the bottom of my CB radio and now it is mounted above the throttle pedal on the access cover. I have to look around the steering wheel to see it, but if I need to manually use the controller it is easy to reach.
Old Mar 1, 2008 | 12:41 PM
ron's power stroke's Avatar
ron's power stroke
...........X2..... because i seem to take the fuse panel off a lot...
Old Mar 1, 2008 | 01:05 PM
superduty4x4
For those going below the cubby are you drilling holes to mount the bracket or using velcro or other means of fastening it to the dash?
Old Mar 1, 2008 | 01:10 PM
That_Guy's Avatar
That_Guy
Mine is the same way, the cb went it first and wasnt thinkin about it at the time.
I just used some short selftaping screws
Old Mar 1, 2008 | 01:40 PM
pbr man's Avatar
pbr man
I was concerned about that at first, but I have enough wire to set the panel on the tranny hump. Or just remove the thumb screws on the side of the controller if I need to take the panel all the way out.
Old Mar 1, 2008 | 02:20 PM
wlihntr's Avatar
wlihntr
yea thats where mine is..i mounted it with some short screws
Old Mar 1, 2008 | 02:21 PM
h2guy's Avatar
h2guy
Just be sure to have it where you can hit that "stop" button when you quickly need to.
Old Mar 1, 2008 | 05:21 PM
jdecker88's Avatar
jdecker88
I mount mine right below the cubby hole, easy to reach and thats where the previous owner had the holes.
Old Mar 1, 2008 | 07:15 PM
cangim's Avatar
cangim
This is where mine is as well, except I turned mine upside down to it would sit closer to the dash. Make sure you read the mounting requirements, some of the inertia activated ones have to be mounted within a few degreas of horizonatal.
Old Mar 1, 2008 | 07:18 PM
PowerStroker?'s Avatar
PowerStroker?
The only non-stock brake controllers I have seen were mounted on the hump. My old man's 06 has one stock where the cubby is on the 99-03 trucks. It's pretty convenient when you're reaching for it quickly.
idealtrucks
2004 - 2008 F150
Aug 12, 2013 08:52 PM
rob_nc
2004 - 2008 F150
May 14, 2007 11:20 AM
ucop27
Dec 1, 2006 10:27 PM
skilife17
1997 - 2003 F150
Sep 11, 2006 09:49 PM
bullhauler
All Things Towing
Sep 18, 2002 09:08 PM
