How much does emissions kill MPG?
Old May 30, 2008 | 03:38 AM
  #31
aurgathor's Avatar
aurgathor
Originally Posted by 85e150six4mtod
The trick is to get your compression and other factors up for efficiency, and then use EGR to reduce the combustion temp to ward off the nox.
Problem is, efficiency depends on peak temperature, not compression.
Old May 30, 2008 | 10:54 AM
  #32
jimandmandy's Avatar
jimandmandy
Compression is a major factor in efficiency. One of the key variables for an Otto cycle engine is compression ratio. That is one of the reasons diesel engines are inherently more efficient. When gasoline engines went from flathead designs at 6-7:1 to OHV at 8-10:1 in the 1950's efficiency went up. That increased efficiency was masked by bigger engine sizes, much better acceleration, heavier cars, and early automatic transmissions.
We have kind of repeated that in the last decade or so. Modern multi-valve OHC engines with high compression ratios can run well on 87 octane. Instead of more mpg, our cars and trucks got faster and heavier at the same time.
Jim
Old May 30, 2008 | 09:31 PM
  #33
aurgathor's Avatar
aurgathor
Compression ratio effects it only indirectly, mostly through peak temperature.
efficiency <= 1 - (Tout/Tpeak)
before all losses, and various other inefficiencies
Old May 30, 2008 | 11:58 PM
  #34
85e150's Avatar
85e150
Originally Posted by jmcder53
i'm not going to complain to be an expert on this. probably some of the stuff i've heard or read ends up merging with something else. i try to make valid points, but somehow it just seems to keep showing that i'm a moron.
Uhh, don't feel that way. It was not my intention to do that if I did.
There is a basic level of the "science" behind this stuff, and then the various mfg adapt it to their engine lines, sometimes with different methods on different engines. Most folks have more questions than answers. And face it, unless someone is an engineer working on this stuff, or a tech that services it, most people are just reporting what they've read.
You can google search this stuff, check "Wickipedia" and "Howstuffworks"
Howstuffworks "Search"
Then, you can move on to SAE papers, and then international stuff.... it never ends.
It's the internet, you're ok.
allcool
6.7L Power Stroke Diesel
72
Nov 5, 2016 06:51 PM
2gumby2
Aug 24, 2016 11:40 PM
rwillia8
Jun 15, 2011 10:20 AM
Hiflyer746
6.4L Power Stroke Diesel
Apr 1, 2007 08:34 PM
RMbros
1978 - 1996 Big Bronco
26
May 17, 2004 06:53 PM
