Stuck in 4x4
Old Mar 1, 2008 | 12:32 AM
bageera's Avatar
bageera
Stuck in 4x4
Hello, I have a 04 fx4, I was driving along with the truck in 4 wheel high. Then hit the edge of the road and was pulled into the ditch. Snow was up to the door handles. Put the truck in 4 low. Got out, but now i can not put the truck into 2 wheel high. Stuck in 4 wheel low, the 4 low light is on. Iam assuming it is something to do with the IWE. I do not think there is water in the vacum lines.
But then again i could be wrong. Any ideas?
Thanx.
Old Mar 1, 2008 | 09:04 AM
DIRTY289's Avatar
DIRTY289
Not trying to be a smart a**.
But you did remember that to get it out of 4x4 low, that you have to put it in neutral first? (Not park but neutral.)
Bruce
Old Mar 1, 2008 | 09:32 AM
Twinsdad98's Avatar
Twinsdad98
Being locked in low all the time would not be fun. As Dirty mentioned have you gone through the proper procedure to get out of low?? I thought the fail safe for the 4x4 was hi, but I can't recall.
Old Mar 1, 2008 | 10:42 AM
Brad34's Avatar
Brad34
My 04 FX4 did the exact same thing, tried everything..nuetral, reverse, etc. Started heading home with it slowey, came to a stop sign about a mile into the way home, it finally came out of low...
Old Mar 1, 2008 | 11:31 AM
airdog1's Avatar
airdog1
4x4 low range is engaged by the shift change motor on the transfer case. All the IWE's do is lock the front hubs to the axle shafts. If you have a problem I'd look there. Ford has a T.S.B. on this - if you look on this site I think you will find it.
Old Mar 1, 2008 | 12:51 PM
Joe04F150's Avatar
Joe04F150
I'd look behind the hubs to make sure the vac line didn't pull off the hub while trying to get yourself out of the ditch.
Old Mar 1, 2008 | 03:57 PM
F0rdzTuff's Avatar
F0rdzTuff
I agree with the above...Sounds like a vacuum line got yanked.
Old Mar 2, 2008 | 11:03 AM
screwy's Avatar
screwy
It’s not a vacuum line, period. Two completely different aspects of the system. Your problem is either your not in neutral with your foot on the brake, your gears are binding in which case try driving forwards and backwards a little bit and try again, or you have an electrical problem or a mechanical problem with the shift motor. Again not your IWE’s and not your vacuum system.
