Maryland Chapter Join Chapter, Leader:
March B/S Chatter Box
Old Mar 13, 2008 | 06:38 AM
  #691
jr32560's Avatar
jr32560
Originally Posted by BPofMD
Don't remember THAT one.....Have to check my collection. Do you know which album it's on?
I'm not sure-never did buy any of his stuff-just used to listen to it in bars,started listening to him in the early 80s-had a bunch downloaded and burned to cd-will look for that one
Old Mar 13, 2008 | 07:33 AM
  #692
jr32560's Avatar
jr32560
man I sure hope we get more conversation at the march GTG -if not it will be very very boring!
Old Mar 13, 2008 | 07:40 AM
  #693
jr32560's Avatar
jr32560
top tools for a shop
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and flings
your soda pop across the room, splattering it against that freshly-stained
heirloom piece you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the
workbench with the speed of light. Also removes fingerprints and hard-earned
guitar calluses from fingers in about the time it takes you to say, "Yeou
sheeeet...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes
until you die of old age.
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters. The most often tool used by all women.
BELT SANDER: An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable motion,
and the more you attempt to influence its course, the more dismal your
future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads.
If nothing else is available, they can also be used to transfer intense
welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of
intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside the
wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16" socket
you've been searching for the last 45 minutes.
TABLE SAW: A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after
you have installed your new brake shoes, trapping the jack handle firmly
under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool, ten times harder than any known
drill bit, that snaps neatly off in bolt holes thereby ending any possible future use.
RADIAL ARM SAW: A large stationary power saw primarily used by most shops
to scare neophytes into choosing another line of work.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a
drop light, it is a good source of vitamin D, "the sunshine vitamin,"
which is not otherwise found under cars at night. Health benefits aside,
its main purpose is to consume 40-watt light bulbs at about the same rate that
105mm howitzer shells might be used during, say, the first few hours of the
Battle of the Bulge. More often dark than light, its name is somewhat
misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and
for opening old-style paper-and-tin oil cans and splashing oil on your
shirt; but can also be used, as the name implies, to strip out Phillips
screw heads. Women excel at using this tool.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
convert common slotted screws into non-removable screws.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that travels by
hose to a Chicago Pneumatic impact wrench that grips rusty bolts which were
last over tightened 30 years ago by someone at Ford, and instantly rounds
off their heads. Also used to quickly snap off lug nuts.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket
you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used
as a kind of divining rod to locate the most expensive parts adjacent to the
object we are trying to hit. Women primarily use it to make gaping holes in
walls when hanging pictures.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on contents
such as seats, vinyl records, liquids in plastic bottles, collector
magazines, refund checks, and rubber or plastic parts.
Especially useful for slicing work clothes, but only while in use.
DAMMMMIT TOOL: Any handy tool that you grab and throw across the garage
while yelling "DAMMMMMIT" at the top of your lungs. It is also, most often,
the next tool that you will need!
Old Mar 13, 2008 | 07:46 AM
  #694
67nukeford's Avatar
67nukeford
Veteran: Navy
Ha!! That is great!! Good Morning Maryland!!
Old Mar 13, 2008 | 09:55 AM
  #695
BIGKEN's Avatar
BIGKEN
Hello Merry-land...kind of quiet around these parts!!!
Old Mar 13, 2008 | 10:25 AM
  #696
3broncocrazy's Avatar
3broncocrazy
Yes it is......
Old Mar 13, 2008 | 01:20 PM
  #697
BPofMD's Avatar
BPofMD
Veteran: Navy
Hey Guys: Those that plan on going to the Ford/Carlisle All Truck Nationals in August really need to get registered if we are to keep that tent that George (Delaware) went out on a limb for and put down his own $ to reserve!!!! And if you already did sign up for it under the Mid-Atlantic FTE, send George your contact info so 1- he can keep YOU informed of the progress and/or any changes and 2- he doesn't have to cancel the tent (AND our discount for entry)!!! This is IMPORTANT friends....get 'er done!!!
Old Mar 13, 2008 | 06:10 PM
  #698
jr32560's Avatar
jr32560
A husband and wife were involved in a argument, concerning all the time he spent hunting while the household chores were being neglected. After considerable time arguing, the wife said "I'll admit I'm wrong," in a conciliatory attempt, "if you'll admit I'm right."
He agreed and, like a gentleman, insisted she go first.
"I'm wrong," she said.
With a twinkle in his eye, he responded, "You're right!"
Old Mar 13, 2008 | 08:40 PM
  #699
80351's Avatar
80351
Hey ken,
What's Up?
I see know ones around
Old Mar 14, 2008 | 01:47 AM
  #700
jr32560's Avatar
jr32560
man this place was dead last night??
Old Mar 14, 2008 | 03:25 AM
  #701
jr32560's Avatar
jr32560
just got this E mail from my ex wife-yes she was a blonde-------------------------- Be on the look-out for the following virus thats sweeping the country. It nearly wiped out everything I had!
"BUENOS DIAS!
JOU HABE YUST RECEIBED A MEHICAN BYRUS. SIN WE HABE NO GOOD TECHNIOLOGICALLY ADBANCE IN MEHICO, DEES IS A MANUAL BYRUS. PLEESE DELETE ALL JOUR FILES ON JOUR HARDT-DRIBE JOURSELF AND SEND THEES E-MAIL TO EBERYONE JOU KNOW. TANK JOU FOR HALPING ME.
JULIO MANUEL JOSE FELIPE GONZALO JORGE RODRIGUEZ-Jones
(MEHICAN HACKER)"
Old Mar 14, 2008 | 04:01 AM
  #702
jr32560's Avatar
jr32560
good morning maryland chapter-rise and shine
Old Mar 14, 2008 | 05:24 AM
  #703
glruff's Avatar
glruff
FTE Leadership Emeritus
Good morning MD peeps
Old Mar 14, 2008 | 05:36 AM
  #704
flathead95hp's Avatar
flathead95hp
Good Morning Everyone.
Old Mar 14, 2008 | 07:04 AM
  #705
BIGKEN's Avatar
BIGKEN
Hello Merry-land...have a great day!!!
