please help! best hp gains for the money?
Originally Posted by tjbeggs
Few questions first. What tranny? How many miles? how heavy is your boat? Also can you do metal fabrication? or have friends who can?
Now to start to spend your money (you can get some pretty good power with your budget)
First thing to do it the Napa 6637 air filter
Exhaust is next. Minimum new turbo down pipe and gut the cat converter (or go with an new turbo back 4 inch or larger)
Now you need at the very least a pyrometer to watch exhuast gas temps.
Transmission temp gauge if you have an auto
Boost gauge
Larger trans cooler if auto trans (trucool max)
Now all of those things are what we call supporting mods. They don't add alot of power but they lay the ground work to safely and effectively to add power.
Next depends on your plans. A chip will add power. I recommend either Total Diesel Performance.com or DP-tuner.com
Or you can go with bigger injectors and a chip to match. This will give lots more power. But it could also take out your tranny (clutch if a 5sp) if its stock. Then a tranny build will be needed.
that will get you started and give you many more questions to ask. Ask away!
Boost gauge
on
On a stock injector 49 state emmisions truck 60-70 hp is the top HP gain from just a chip. Thats all the injectors are capable of supporting. More fuel is needed above that. NO chip of any shape or form on a stock 49 state emmisions truk will go higher than that. Now Banks when they quote the 120HP gain they are using a California emmisions truck that has larger injectors then the 49 state models.
Banks hard parts (intercoolers, turbo housings) and even their chips are decent stuff but they are WAY over priced. Their intercooler set up is nice but there are much better setups out there. Their chips are mild. All in all Banks is a waste of time and money! One thing that kills me about Banks is that they use a drop in K+N filter. That is really bad!! For you new guys don't use a K+N drop in filter. You need to get rid of the factory air box ASAP!! It leaks dirt no matter what filter is in there.
xcrunner2616
01-14-2012 11:22 PM
Royson12
16
02-21-2008 04:23 AM
Mil1ion
20
04-28-2003 12:04 PM
