Fuel Line Fitting?? PIC
Old Feb 29, 2008 | 02:40 PM
fluidp's Avatar
fluidp
HI, Can any one tell me how to get these fuel line fittings apart??
95 PSD
I removed the clips and I assume they should just pull apart?? BUT???
They are the fittings at the front of the motor where it goes from steel tube to braided hose.
Old Feb 29, 2008 | 06:33 PM
fluidp's Avatar
fluidp
IN case anyone is interested, I found out from a friend that a speacial Disconnect Tool ir required to separate the fittings. You should be able to pick one up at your local auto suppy store. I will get one tomorrow and give it a try.
Old Feb 29, 2008 | 06:37 PM
c00nhunterjoe's Avatar
c00nhunterjoe
yup, i have the whole kit, i can remove any make model or size
Old Feb 29, 2008 | 06:38 PM
c00nhunterjoe
in most cases i would say make sure you spray the insides down with oil really good to make sure its comes loose, but yours looks well lubed....lol in any case spray some brakleen in there first to get all that grit out of there and then spray some silicone or wd-40 to help lube before dissassembly
Old Feb 29, 2008 | 06:45 PM
Hussler's Avatar
Hussler
Really .. I know my 1990 gasser F250 had them but did not know our diesels did. Interesting, guess I've not been that far in the engine yet. The tool just slide down and it pulls apart.
