so im leaving to go out of town for the weekend and my truck disagrees.i was driving about 45 mph when a loud constant grinding noise began from the front tire,so i pulled over and it stopped ,i jacked it up took tire off and could find nothing wrong. the front end was rebuilt 8 months ago-new upper, lower ball joints,new control arm,shocks,tie rod ends,brakes and rotors were done 3 months ago. right now im kinda at a loss ,thinking maybe cv axle,what else do i need to look at?
I had the same problem, only at lower speeds/RPMs. What I found out was that I had some nasty positive camber at low road speed that was causing my front skid plate to rattle against the frame and/or exhaust.
It sounded almost exactly like what you describe. After a full four-wheel alignment and shoring up of the skid plates, my '98 sounds almost as good as the day I bought it.
i have looked over everything twice still have found nothing.i cannot get the grinding sound to repeat itself. however i can feel something in the steering wheel when driving,but its so small that i wouldnt notice it if i didnt drive the truck everyday.im baffled...........
Sounds like you might've gotten a pebble jammed in your brakes. Disc brakes are both minimally protected from debris & mostly immune to debris. However, inevitably, just the right sized bit can get picked up off the road, thrown into just the right place & get jammed into the brakes-to produce the symptoms like you mention. Usually the "constant grinding noise" is short lived. Often such a noise, that starts spontaneously, will be changed with application of the brakes. Most of the time such debris rapidly abrades & gets spit out on its own, applying brakes tends to speed up the process. Stones generally make noise only a few seconds.
Once got what might've been a small rusted steel nut jammed between the caliper & rotor. The grinding persisted forcing me to pull the wheel. Couldn't pry the battered chunk of steel out. Put wheel on, backed up, hit brakes, debris popped out.
well i have been over and under my truck completely and i have found nothing. so club wagon it seems very apparent to me that your diagagnosis was correct.wouldnt never imagined it was possible but then again.......
I had a grinding/howling noise on my 06 KR 4x4 only when turning left, even just changing lanes. It was most noticeable from about 20-50 mph but really was there at all speeds just got lower frequency when slow and drowned out by wind and road noise when fast. I jacked up the front end and didn't feel any play or drag when the wheels were spun. I took it to the dealer and it was the wheel bearing/hub assembly on the left front. I hope this helps.
