Front End Grinding noise
Old May 10, 2014 | 04:21 PM
ffdono14's Avatar
ffdono14
Hi Guys,
I'm new to the forum. I used to be on the powerstroke forums when I owned a 99 f250 a little while ago. Just bought a 2006 crewcab F150 xlt about 2 months ago, and for the past month there has been this unusual grinding or whirring like noise coming from the front passenger side wheel.
I took it to the mechanic and he found a bad wheel bearing on drivers side and replaced it but that wasn't the issue. He could hear the noise but wasn't able to figure out what the actual issue was.
The noise only happens when my foot is on the throttle. (not when coasting) and i also just discovered that it doesn't make any noise at all when put in 4x4.
Is this an issue anybody has heard of before? Im not sure where to go from here.
Thanks for the help,
Kevin
Old May 10, 2014 | 06:38 PM
danorules's Avatar
danorules
It's your Iwe, look above in the " stickies" section. You will get all the info you need in that thread
Old May 11, 2014 | 04:19 AM
VTX1800N1's Avatar
VTX1800N1
Your symptoms suggest bad check valves: http://www.f150forum.com/f72/how-dia...72/?styleid=14
Old May 11, 2014 | 05:32 AM
60DRB's Avatar
60DRB
...and tell your mechanic to read it too.
Old May 11, 2014 | 09:06 AM
danorules's Avatar
danorules
I was thinking that too
caprang
6.4L Power Stroke Diesel
Jun 23, 2011 11:51 AM
db47
2004 - 2008 F150
Nov 2, 2008 01:01 PM
