Dash removal
Old Feb 29, 2008 | 08:31 AM
PROSTOCK's Avatar
PROSTOCK
Dash removal
In preparation for resotation, I'd like to know if it's possible to "unbolt" the entire dash? Mine has some minor surface rust on the backside I want to take care of, and I think it would be much easier to re-work the dash wiring from the back as well.
Old Feb 29, 2008 | 08:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Garbz2 will know for sure, but I think it's welded on.
I see no bolts or bolt holes in the parts catalog illustration, and in the text section under C5TZ-8104320-A (the dashes part number), it doesn't list any hardware.
Old Feb 29, 2008 | 09:01 AM
matt2491's Avatar
matt2491
The gauge cluster assembly comes out. There's a few screws on the top and bottom...
Old Feb 29, 2008 | 10:23 AM
PROSTOCK's Avatar
PROSTOCK
That's the way it looks, but I was hoping....
Old Feb 29, 2008 | 02:24 PM
airharley's Avatar
airharley
It's spot welded in. If you look along the cab dash panel mating area you can see tabs with the dimples on them. I'd drill the spot welds after I presicely marked the location of each tab and then pull it out. Just paint the under side of the dash panel and leave the tabs bare. Then fill in the tab holes with a welder, clean it up and spray the interior. Just me though.
Old Feb 29, 2008 | 11:31 PM
camperspecial65's Avatar
camperspecial65
its welded along the windshield pinchweld and at the lower ends of the dash..
In short, no, unless you wanna do a ton of additional work
- cs65
Old Mar 1, 2008 | 07:41 PM
es2rider's Avatar
es2rider
In the 65-66 Ford Illustrated Facts and Features Manual it states:
"Great cab strenth is further increased by welding the instrument panel to the front door pillar assembly at each end and to the top of the cowl."
You would probably damage it trying to get it out.
I scuffed mine up with the red scotch pads and coated it with a self etching primer. (Lesonal )
Good luck, Doug
Old Mar 1, 2008 | 09:01 PM
garbz2's Avatar
garbz2
Fully spot welded... sorry...and a pita to remove. Usually a 3 blader on the sawzall...
I typically get up in there with some scotch brite and spray some rustoleum WHITE paint on the inside... It is a treat to see up in there when its bright.....Amazing the difference.
When i would scrap a truck i would cut out and save the dash for repair panels for huge radio holes and such.
Garbz
