Sticky Valves...
Old Feb 29, 2008 | 08:05 PM
FitchBanjos's Avatar
FitchBanjos
Sticky Valves...
How do you know when you have a sticky valve? Would the symptom be the same a vaccum leak ?
Old Mar 1, 2008 | 09:50 AM
BobbyFord's Avatar
BobbyFord
If the valve sticks closed the result will be a bent pushrod.
Old Mar 1, 2008 | 10:19 AM
FitchBanjos
OK Thanks. I cant figure out why the mixture screw on the right side of my carb has no affect on my idle. I figured it was a vaccum leak but someone else suggested that it might be a clogged passage in the carb. The engine idles fine until I drop it into gear then it shakes pretty bad. Runs fine off idle.
Old Mar 1, 2008 | 10:34 PM
swann79's Avatar
swann79
Carb rebuild?
