U-Joint Question???
Old Feb 28, 2008 | 07:35 PM
kris bassett's Avatar
kris bassett
U-Joint Question???
I recently had the yoke on the rearend of my 76 F150 bust. I ordered a new one from JBG and when I opened in up I could tell it was going to take a larger U-Joint than my previous one.
My question is this...Are there any U-Joints that will work with this instead of having to ship this back and wait for another one? It would need to have one side small enough to fit the drive shaft and the other side big enough to fit the yoke?
It seems like I have seen somewhere that sell "conversion U-Joints" for this purpose.
Any help would be apreciated!
Thanks
Kris
Old Feb 28, 2008 | 07:44 PM
kris bassett
Would this U-Joint work and if so do you suppose my NAPA could get it for me?
http://store.summitracing.com/partde...5&autoview=sku
Thanks
Kris
Old Feb 28, 2008 | 08:43 PM
sedly's Avatar
sedly
Take a measurement on both the drive shaft and the yolk on the rear end.A local part's store should be able to help you out.
Old Feb 29, 2008 | 02:47 AM
75F350's Avatar
75F350
Your problem is not uncommon, and you are actually looking for a "combination joint". Not the best solution because they are not as common as "square" joints, so a field repair might be difficult, but these combo joints are not that difficult to find.
Old Feb 29, 2008 | 03:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford part number: C5TZ-4635-F
Spicer part number: 210392-X
U-Joint ~ Spicer Type: 1310/1330 combination. 2 cups are 1310's, 2 are 1330's.
Either the Ford or Spicer part number can be crossed over by autoparts stores to the brand they sell.
This u-joint was used on many 1965/79 F100/150/250's.
Old Feb 29, 2008 | 04:39 AM
kris bassett
Thanks guys. I looked up the part number of the yoke and it is a 1330 and my driveline I know for sure takes a 1310. I should be up and running in no time assuming my local parts store has what I need.
Kris
80FlareSide
Aug 26, 2010 07:36 AM
kris bassett
Mar 5, 2008 03:37 PM
toolman1010
Mar 22, 2007 02:08 PM
f1drivr
1947 and Older Ford Trucks
Sep 21, 2004 01:20 PM
Jag Red 54
May 28, 2004 10:22 AM
