I just got finished porting and polishing a set of cleveland heads. I cleaned them all up and painted them. The heads are in good shape. They have already been milled before. Does anyone know how much I could get for them if I sold them.
Thanks
77 F-150 4x4 lifted 4", 33" swampers, 351M
435 trans
Depends on where you are, and how much you opened the combustion chamber to. I have a set of 2v 351C heads that started out at 78CC's after some massive porting and polishing, The heads are now useless to be because the CC's went to 92. Which in turn now make me have to go with a Domed piston to get 10:5 1 out of it and those Pistons are $900 to be made takes 2 months. I would really like to drive the car before then. Also i had them milled for guide plates and setup Roller Rockers.
Here is how they are setup.
Brand new valve seats, guide. 3 Angled Job. No Valves (if i sell them) Milled for screw in rocker studs. Converted to use on a 302 Windsor (manifold needed for these to work, any boss manifold will work check ebay there are/were tons of them)
When i say converted i mean they water ports have been changed and redirected for the BOSS design. In essence these are Clevor heads.
I'll take $500 for the pair. OR trade someone for a set of Aussie 351C closed chambered heads.
Yes they can be switched back to work on 351C or 351M. Just will need to remove the plugs and plugs the new holes.
