Transmission Leak Help!!!!!!!!!!!
Hey, hows everyone doing?
I need major HELP!
My 01 f250 V10 truck has a a transmission leak. the leak is on the metal line going in to the radiator.
it looks like where the metal line connects to the radiator is leaking. it is a bad leak.
i am ok when it comes to fixing cars, but im no mechanic by any means!
what do you all think is the problem, and who would i fix it?
Replace the line?
dose this happen a lot?
how much would you think(ballpark) it would cost me to fix if i took it to a shop?
I have been adding fluid for the past day. about a qt every 2-3 days.
PLEASE HELP!!!! im off to work, i cant search now. THANKS GUYS for any help you can give me!!!!!!!
I need major HELP!
Replace the line?
Thanks Redford for the info
from what i see the hose is not cracked, im waiting on a buddie to come up and hold the clamp on so i can push the pipe back in and to drive me to the 24hr walmart for atf
the dip stick showes just a little bit at the very tip.
you guys think 1-2 qts should do it?
Well, I got the metal pipe further in the rubber hose, and placed the clamp on in the right place. so far so good. no leaking.
I dont like how that line is. its in a real bad location. during off or even on road driving it is way to easy for something to hit or snag those lines, knock one out, drain ur trans while driving, and really screwing your trans up.
quick question- since it leaked, i put one bottle of trans STOP LEAK(half qt), one qt of mobile ATF mercon+mercon V, and 1 qt of walmart supertech atf(made for dexron lll and mercon brands)
is it ok to run this for a while? im planning a trans flush in 2 monthes. can i wait or should i do it now. i am low on cash. I do no towing.
thoughts?
Again,
Thanks redford for your input
I thought this was going to be a 400+ shop bill, but turned out to be 2 minutes of laying on the pavement!!!!
thoughts?
Again,
fitzy67
1997-2006 Expedition & Navigator
05-11-2019 12:25 PM
DeTempleMobileDetail
08-07-2014 10:59 AM
smashclash
12-06-2010 06:16 PM
acheers
04-16-2003 01:04 PM
