Missing Due To Timing Chain?
Old Jun 3, 2002 | 09:22 AM
Ugly's Avatar
Ugly
I have a '73 351c 2v. It starts fine however while driving at a constant speed (+/-) 35-50mph I notice a miss. While checking the timing it doesn't jump around. Is it possible that the timing chain/gears are bad and I notice it only while it's under a load? I know their are many other things that can be the cause, but this is just an idea.
Ugly
Old Jun 3, 2002 | 11:02 AM
Fastcat's Avatar
Fastcat
If that's all it's doing I dought that it's the time chain. Could be bad spark plug/s, vacuum leak. carb problem, Vac advance. I would start with the easy stuff first.
Old Jun 3, 2002 | 11:39 AM
Ugly's Avatar
Ugly
Thanks Fastcat,
It could be the Vac advance, I just installed a new distributor. And honestly I can't say that I noticed "That" problem before. Would it be that it's not working or just needing adjusted?
Ugly
Old Jun 3, 2002 | 09:49 PM
TomThrall's Avatar
TomThrall
