I have an 87 f-250, 460, 4-speed, and I was wondering for the sake of fuel efficiency and less rpms on the motor, are there and overdrive 5-speeds that are a direct bolt-in
the 4 speed and the 5 speed have different parts.. hydraulic clutch on the 5 speed, different clutch disk / flywheel, clutch pedal because the linkage is different.
So you are saying it uses a different flywheel than the 4-speed? and why would the clutch pedal need replaced?
Sorry I miss read I thought it was auto....you would be fine with the flywheel. you would just need a clutch kit and a new clutch master cylinder, slave cylinder and new line . The pedal would be fine as well.
