Does anyone know offhand the torque spec on the ratcheting lock nut that holds the rear axle hubs on? I smelled brakes when i got out of my truck, felt the RR wheel and it was very HOT. Took the wheel off, and removed the caliper. The pads just fell out, one fell off the backing, and the other was shot. The rotor was trashed, the other side the same. The parking brake shoes were also trashed, probably because i accidentally left the brake applied when i left and went into town before i noticed the squeaking. Anyway, i had to remove the axle shafts and the hubs to gain access to the parking shoes.
All this, and i still only want to know the torque number. thanks.
Kris, I know you have to take the axle out to change the rotors on a dually, but I didn't know you had to do that on a srw. Or is that just if you want to change the pads for the emergency brakes?
beee right back, got it in the truck
This is SRW mind you, and right from the dealer techbook.
Tighten to 81NM (60 ftlbs)
new brearings:
ratchet back 5 teeth (clicks)
(looser)
used bearings:
ratchet back 7 teeth (clicks)
(looser)
This is an important thing to follow.
Sorry I havent paid much attention lately. Getting a concussion sucks!
Yea the clicks will get you. So will writing someone you dont remember, a message two times, that was probably an hour long each. LOL I got a concussion a couple of days ago, and just havent been with it......
