Sponsored by: Auxito
5W-20 engine oil???
Old Dec 13, 2001 | 08:23 AM
  #31
ryanstruck's Avatar
ryanstruck
5W-20 engine oil???
[updated:LAST EDITED ON 13-Dec-01 AT 09:23 AM (EST)]Could you tell us which Ford dealership you work at? Or show us some documentation which says to use 6 quarts? I would assume you would have that being a manager. Not that I don't believe you, but I have been to 2 dealerships, a Jiffy Lube and a Havoline Quik Lube Center, and all have used 7 quarts. 6 is at the regular price and something like $3 on average for the additional quart. With out fail, always 7 quarts. And on both my 99 F-150 and my 86 F-250, that fills just a little more than midway on the cross hatching on the dipstick. Like I said, I'm not saying you're lying or anything, but it does seem a little odd to me anyways that a brand new member with this as the only post comes here after this discussion was supposedly dropped a while back other than the 5-20/30 discussion. I would seriously like to see the tech manual which says to use 6 quarts of oil. So if you could post it on a link, or have a link to check it out that would be great.
Ryan
Old Dec 13, 2001 | 09:42 AM
  #32
Deebo's Avatar
Deebo
5W-20 engine oil???
>I'm the ser. mgr. @ a Ford dealership. The correct amount is
>6 qts.
>The max line on the dipstick should never be exceeded, but
>it is not
>necessary for the level to be there, and will actually be
>about half
>way to a little over that with 6. Mark your dipstick there
>after a 6
>qt. change and use that for full. Ford confused people years
>ago with
>that max. mark and I sure don't know why they went back to
>it. As for
>5-20, I still use the 5-30 originally recomended for my gen
>I sc, but
>the Ford 5-20 is supposed to be synthetic that they are
>selling for
>regular price now trying to get people to use it. It is
>recomended for
>all the newer 97/ up triton engines, but I've stuck to the
>5-30 for some reason.
Ok Sr,MGR.
If all above you say is True...
Isn't Ford Motor Company a ISO 9002 Registered company?
If that is true. Your Dealership and Ford Are Probably not in accordance with what ever the criteria mentioned in your registration.
Or did Ford just write their criteria for this oil level issue with Wide open areas for all of us to guess at.
If the Dip stick is wrong, showing the full mark. it should be modified and the guidlines stated TO THE TEE... what the oil level instructions should be. Not "A Safe Operating Level"..
Simple as this:
Your new Supercrew takes 7 quarts of oil.
This will fill it to the full mark.
OR..(Install a new Dipstick newer than the 1977 dip stick used in the LTD's).
Your new Supercrew takes 6 quarts of oil.
This will Fill it to the full mark.
Old Dec 13, 2001 | 04:25 PM
  #33
MikeTexas's Avatar
MikeTexas
5W-20 engine oil???
I have a 1993 EB Explorer I bought new. Switched over to Mobil 1 10-30W synthetic at 8K and have used it ever since. My Explorer now has 115K miles on it now (about 30K hard towing) and still does not use over 1/2 qt. between changes, which are every 4K miles. My next new vehicle will probably be a 5.4 Supercrew. I plan to use Mobil 1 5-30W in it, due our hot Texas summer weather, which often is usually between 100-112 degrees. That kind of heat, when towing and loaded,with the A/C on, is mighty tough on an engine. So high quality oil, of the right viscosity, is a must. Mike
Old Dec 14, 2001 | 05:46 AM
  #34
drc's Avatar
drc
5W-20 engine oil???
i change my own oil and always have. my 2001 5.4l supercrew with tow package takes 6.75 quarts to the max. line on the dip stick and that amount includes changing the oil filter. sounds to me like your over filling by 8 oz. and that is just as bad as under filling.
Old Dec 14, 2001 | 01:48 PM
  #35
daniel01's Avatar
daniel01
5W-20 engine oil???
i work at the engine plant in Windsor, and spec book for f series 5.4 liter engine calls for 6.5 to 6.7 U.S. quarts even considering oil filter use ... if you have a different vehicle or engine ask and i'll see what i can do ... p.s. different vehicles sometimes means different oil pans etc.
Old Dec 14, 2001 | 01:54 PM
  #36
daniel01's Avatar
daniel01
5W-20 engine oil???
i am not sure if every ounce of oil is drained during an oil change .. depending on temps and how long drain plug is out there could be variences so why split hairs ... dealership should be trained to at least change oil. :-)
Old Dec 16, 2001 | 02:54 AM
  #37
f150sleeper's Avatar
f150sleeper
5W-20 engine oil???
Let's just say that someone goes out and buys a used 97 and up f150. Now they get this truck but its missing the owners manual. Does that mean that he cant change his oil because he doesnt know how much he needs to put in down to the tenth of a quart. Anyone I have ever known has used the dipstick to determine how much oil needs to be put in. I like to keep mine filled near the full line as a just incase cause you never know when a gasket or a hose to a remotely mounted oil filter could blow. Having that extra quart could save your engine from frying.
P.S. My dad works at a Ford dealership and any f150 theyve ever had come in for a oil change has had 7 quarts put in it.
1979 F150 Custom 2wd C4 302 painted ford blue, bored .040 over, flat top pistons with valve reliefs, Edelbrock Performer cam, carb, and intake, stock heads til next spring, MSD Ready-To-Run distributor, MSD Blaster 2 coil, Edelbrock air cleaner and valve covers, Dynomax headers, dual exhaust with Flowmaster 40 Series mufflers, 38 gallon fuel tank(how i can drive it further than around the block) 9" rear end with 2.75 gears and open diff to change to 3.50s and locker next spring.
"Your only as fast as me until the light turns green"
Old Dec 16, 2001 | 06:03 AM
  #38
daniel01's Avatar
daniel01
5W-20 engine oil???
from what i can gather oil level on dip stick should be between top of "hatched" area and "o" mark ...this is from diagram on spec sheet, but i've seen soooo many different dip sticks just for different mod numbers that i'm not sure if the markings have change from either year to year or model to model on the tritons alone,
hey, it's not brain surgury - it's oil - it's a fun topic, and definitely debateable.
Old Dec 16, 2001 | 07:35 AM
  #39
Reueld's Avatar
Reueld
5W-20 engine oil???
Old Jan 2, 2007 | 03:30 PM
  #40
rsylvstr's Avatar
rsylvstr
Originally Posted by johnh2000
I'm the ser. mgr. @ a Ford dealership. The correct amount is 6 qts.
The max line on the dipstick should never be exceeded, but it is not
necessary for the level to be there, and will actually be about half
way to a little over that with 6. Mark your dipstick there after a 6
qt. change and use that for full. Ford confused people years ago with
that max. mark and I sure don't know why they went back to it. As for
5-20, I still use the 5-30 originally recomended for my gen I sc, but
the Ford 5-20 is supposed to be synthetic that they are selling for
regular price now trying to get people to use it. It is recomended for
all the newer 97/ up triton engines, but I've stuck to the 5-30 for some reason.
Yes, the age old question....
just my story: when i took my truck to the dealer in Yorkville, NY, they said FMC "approved" (or was it "doesn't care anymore") if i use 5W-20 (blended) or 5W-30 (dino)....they put 5W-30 in, so i had to ask...after the fact of course.
tonyford
Escape & Escape Hybrid
Dec 6, 2011 09:40 PM
tonyford
Oct 6, 2011 11:17 AM
bill11012
Modular V10 (6.8l)
20
Nov 25, 2009 06:14 PM
zillah
Oil & Lubrication
Jan 23, 2009 09:17 PM
94E1504.9L
1997 - 2003 F150
63
Apr 14, 2008 04:17 PM
