Speedometer Drive Gears
Old Mar 8, 2008 | 11:03 AM
matt2491's Avatar
matt2491
Hey, thanks a lot.
It says I need a 22 teeth driven gear, but naturally Ford only has 20, 21, and 23 teeth gears...
Would it be better to go one up or one down?
Old Mar 8, 2008 | 11:05 AM
FitchBanjos's Avatar
FitchBanjos
I "think" the 20 tooth is the closet match to your 8 tooth drive gear. Maybe someone else will chime in.
Old Mar 8, 2008 | 11:12 AM
matt2491's Avatar
matt2491
20? Are you sure?
I put in all my info and it came up with 22.39289853004139 teeth... Why would I go with 20 if they offer 21?
Old Mar 8, 2008 | 11:45 AM
FitchBanjos
No I am not sure . Thats why I put "think" in quotes. Logic leads me to believe that the gear needs to have an even number of teeth to run on a 8 tooth drive but, it could be acceptable with plastic speedo gears.
Old Mar 8, 2008 | 11:54 AM
matt2491's Avatar
matt2491
Thanks for the help, Banjos.
I just think it wouldn't matter whether its odd or even, the gear will just be slightly bigger as long as the spacing between each tooth was correct...
