there's a demon in my engine!
Old Jun 20, 2002 | 02:29 PM
beartracks's Avatar
beartracks
ouch, ouch. That's too much intial timing for your combo. i suspect your running hot. A little extra timing is good on these engines but I think you crossed a line.
bear tracks
Old Jun 20, 2002 | 02:30 PM
flatliner's Avatar
flatliner
Your initial timing setting may not work well with stock dist. Also, what size/kind carb are you running?
Old Jun 20, 2002 | 02:32 PM
beartracks's Avatar
beartracks
As for the Demon, I've got one on top of my engine. Heh, heh!
Bear
Old Jun 20, 2002 | 04:59 PM
JETHRO351's Avatar
JETHRO351
Every couple of times i run my freshly rebuilt 400 (see gallery) I turn the key off it "diesels" for a half second and then it rotates in the opposite direction for three or four rotations. Am i too far advanced/retarded timing wise? Too rich/lean? Or am I just in need of an exorcism? Please help, I want to keep my beast alive and happy!
Old Jun 20, 2002 | 05:55 PM
shazam's Avatar
shazam
What was the cam installed at and what are you running you timing at now ? And just how high of a comp. motor you have there.
Old Jun 20, 2002 | 07:14 PM
JETHRO351's Avatar
JETHRO351
comp cams 260H: 260*total duration 0.484 total lift. No advance or retard on cam installation. Roughly 8:1 compression(stock). 18-22 deg initial advance with no vacumm connected@500-650rpm. (doesn't fluctuate, just can't remember.) Thanks in advance!!
Old Jun 21, 2002 | 11:15 PM
JETHRO351's Avatar
JETHRO351
Holley 600cfm vac secondary carb w/ manual choke. 68 jets in the primaries. See gallery for rest of specs.
Old Jun 22, 2002 | 08:41 PM
flatliner's Avatar
flatliner
If you're going to set your initial timing that high, you may want to do it with the vacuum hooked up. Otherwise, I'd set it a lot lower.
Old Jun 22, 2002 | 08:54 PM
JETHRO351's Avatar
JETHRO351
Sorry! The vacumm is connected and its about 22*@800rpm. Just went out and put the light on it earlier today. Vacumm is tee'd from manifold to above throttle port to advance can on dist.
Old Jun 22, 2002 | 11:40 PM
wayne_j's Avatar
wayne_j
Sounds like you have you vaccum advanced hooked to the wrong source. You shouldn't be getting that much advance at only 800 rpms. Unhook the vaccum advance, set your timing for 10-12*. Hook your advance into a "PORTED" (Ported means above the butterflys, on the 600 Holley I believe there is an port on the right side of the idle plate) outlet and recheck. Your timing should be around 36* total @2800 to 3000 RPMS.
Old Jun 23, 2002 | 12:57 AM
Brian S's Avatar
Brian S
