balancer counterweight
Old Feb 26, 2008 | 03:44 PM
dutchlincoln79's Avatar
dutchlincoln79
Howdy guys,
As my balancer isn't in a great sape anymore, i want to replace it.
I have a 400 engine.
I also have a 351M engine in the barn, and it has a small different balancer.
What weight do i need?
28 Oz, or 50 Oz?
When i take a look here, it say's that the balancer is for a 351M/400 and they don't make a difference in it.
http://www.professional-products.com/dampersProductSBford.php
What's the problem when i put the wrong weight on it?
Thanks.
ps. original balancer say's: DIAE-AA SD H8
Old Feb 28, 2008 | 02:08 PM
mustang81's Avatar
mustang81
could be out of balance. I have a 351m and convert to 400 and don't know the difference between the 351m and the 400 balancer. I only have a 351m balancer.
You say it's smaller balancer on 351m ?
Old Feb 28, 2008 | 02:15 PM
hollenjoe's Avatar
hollenjoe
hmmm im converting my 351m into a 400 too, is there a real diference, how do we adjust it for a 400, ive heard it has to be moved 12+ or something like that...... help!!!!
Old Feb 28, 2008 | 02:26 PM
dutchlincoln79
Yes.
I have a 351M here in the barn, and it weights less, and is a bit thinner.
From what i've recovered so far, is that the weight is different due to a heavyer crank in the 400, but the balance weight is the same, and should be 28Oz.
Tomorrow i intend to pull the old balancer off, then we'll see...
Old Feb 28, 2008 | 02:30 PM
hollenjoe's Avatar
hollenjoe
yeah this is very important and could cause intenral negative vibrations in the rotating asemble...... let me know how it goes so I copy whatever you did, thanx..
Old Feb 28, 2008 | 02:53 PM
mustang81's Avatar
mustang81
on page 7 might help http://www.projectronco.com/Technica...e_build_up.htm
Old Feb 28, 2008 | 03:00 PM
mustang81's Avatar
mustang81
http:http://www.projectbronco.com/Technic...e_build_up.htm
Old Feb 28, 2008 | 03:21 PM
dutchlincoln79
you're trying to say:
The 351M uses a different harmonic balancer than the 400 -- It is best to buy a new 400 harmonic balancer to go along with a 400 crankshaft. You can use a 351M balancer, however, you will have to rebalance the 400 crankshaft by adjusting the counter weights to bring the assembly into balance. Also, the timing marks on the 351M balancer will be nearly useless on a 400 crank -- I know because the engine shop used the 351M balancer on my engine. I had to set my timing at 20+ degrees to get the engine properly timed.
Old Feb 28, 2008 | 03:23 PM
hollenjoe's Avatar
hollenjoe
yeah i read that already it says you have to insatll it 12 + in the key ways...samo say it isnt nedded..
Old Feb 28, 2008 | 03:30 PM
dutchlincoln79
i'll take pics of all three tomorrow if the weather's nice here.
(have to work on the street...)
Old Feb 28, 2008 | 04:40 PM
hollenjoe's Avatar
hollenjoe
jaja ok cool...
