Rear end choices!!!
1) the 1969 Torino 9" rear.
2) the 1972 F-series truck 9" rear.
I'm tired...FIRST on that calls is gettin' a visit from Me & the Girl TODAY with cash.
This has turned into a cluster-you-know-what!!!
When we get it home we WILL figure it out and deal with it AND make it work!!!!
It's tiime to kick the tires & lite the fires!!!!
begging people to sell me their T-bird-Cougar-Mark-8-or whatever IRS
setups for waaayyy too much...this past weekend found a local who was
more than happy (sort of) to part with a 9-inch rear end for almost nothing!
It's Home! It was advertised as a 1970 F100 unit but I'm not so sure...
I was told it has a3.50:1 gear but didn't know much else from the P.O.
They were gonna put it in a 1966 Mustang Fastback...
Cancelled by a heart-attack...
-Maybe youse' can help me figure it out...HERES THE SKINNY:
Flat Top (& bottom)
straight tubes (havent measured O.D. yet)
drain plug on lower pass side
2 1/2" wide brake shoes!
End of axle shafts have 2 holes & 1 dimple! (31 spline?)
Backing plate blots require a 3/4" socket to remove nut! (large bearing?)
Inside backing plate-to-plate is about 55 1/2"
Spring perch hole-to-hole is about 41"
Shock mounting center about 31"
Casting Numbers: C6A_
Date Code: 6F29
Some other numbers cast in the housing I dont recognize:
1_38
DIFF LL
6978
Some of the numbers are difficult to read...
I am doing the 4-bar now. Shockwave 8007, universal triangulated 4-bar. Around $1200 including the mounts and a schrader valve kit to use shop air to begin with. Installing it with the 9". Check out my gallery for "August progress" to see what it looks like so far and find if you really want to do it.
Preliminary measurements of my set up, and plugging the numbers into a spreadsheet I found on the net, show my Anti-squat to be at 99.7% with 100% being totally neutral. Instant center comes out somewhere around 67" in front of the rear axle at about the level of the cab floor. Should handle well from all I have read so far.
So far the install has been relatively easy. Next step is the X-member to mount the shockwaves on. I am playing with the idea of adapting the sway bar from the front of the motor donor (86 E-250) to the back of my pickup. We'll see how that pans out.
...looks fairly straight forward...thanks for the heads-up!
I was just out in the garage looking at the casting numbers again
and a couple of 'em are a little "abused" to say the least...so I may have
gotten them wrong. Now a few of them sort of look like:
C6A_ might actually be C5A_
There is a group of numbers cast into a circle near the top of the
center section that look like 81875.
I guess I'll know more when I pull the center out...
grinder & presto... the casting numbers apeared clearly !!!
C5AW 1965 full size Ford "something"
CF29 date code- June 29, ?
Another series of numbers: AB88A
The numbers in the circle near the top of the housig are: 691873
Still have not confirmed the gears...
