I have replaced the trans gasket already. I know its not leaking from the pan. Its coming from the rear of the trans around the mount. It only leaks when its hot after driving. Is there any other place that I should check?
Thanks
There is a seal there that stops fluid from coming out, but that seal can wear and leak into the tailhousing.
So that means there should not be any fluid in the housing? if so then i need to remove the tailhousing and replace that seal...if i understand this right!?
Sorry I wasn't very clear there, I'm no tranny expert but I have rebuilt quite a few and I have never seen one that didn't have fluid in the tail shaft, they need it.
What model tranny do you have? Is it four wheel drive?
