I'm looking to do a little body work on my 51. What guage and type of steel would you use for doing fender work?
And also, I have to do some welding on my dash as well.
Thanks
yep 20 guage for body unless i was working of somthing like a rollpan or somthing to that sort. the i used 18...but im with oldgreenf1 22 seams thin after using 20 alot.
Cold rolled steel is what you want. You can recognize it by it's silvery "steel" color. Hot rolled steel is the less desirable alternative which can be recognized by it's black color (if you must use hot rolled, the black oxide coating needs to be sanded off before welding or painting. I prefer to use the same or one gauge thicker sheet to the area I'm working on. It makes welding a little easier and gives you a little extra "meat" for filing and sanding when working out imperfections/smoothing welds and doesn't distort quite as easily. I typically use 18 ga for exterior body repair on our trucks.
what about satin coat steel? it is available in al of the above mentioned gauges.
the thing about cold rolled steel is if you use it in an area where you can't finish the backside which also means that it is also a possibility it could be in a location where it can sweat behind & rust from the inside out. satin coat has a weldable galvinized coating that resists rust.
just my experiance with coldrolled
mikie
near ottawa canada
58 merc 10 panel, & 64 econoline p/u
what about satin coat steel? it is available in all of the above mentioned gauges. The thing about cold rolled steel is if you use it in an area where you can't finish the backside which also means that it is also a possibility it could be in a location where it can sweat behind & rust from the inside out. satin coat has a weldable galvinized coating that resists rust.
I haven't heard of satin coat steel before and I haven't seen it at my local steel vendors.
I don't like to weld anything galvanized. The fumes are dangerous. Sometimes, I just can't hold my breath taht long (LOL).
I use a rattle can weld-through primer on the backside of patches to deal with the rust issue on cold rolled sheet. It is available through most body shop supply stores. Zero Rust is another acceptable back side coating.
If you cannot get at the back side of a patch to rustproof it after installation then I would use weld thru primer on the back side before welding the patch in place.
OOPS sorry Randy we were both posting the same info at the same time.
