E4OD troubles
Old Feb 25, 2008 | 11:14 PM
shanett306's Avatar
shanett306
E4OD troubles
was pulling a empty car tailer home last night and my tranny started to slip in the top of third gear and all the way through od. It felt just like a standard tranny vehicle with a sliping clutch. my questin is how do I know weather it is the tranny sliping of the torque converter?
Old Feb 25, 2008 | 11:19 PM
MTNWOODY's Avatar
MTNWOODY
OD light flashing? Codes? Mileage? Fluid level? Doesn't sound good.
- Ish
Old Feb 26, 2008 | 08:40 AM
MADVAN's Avatar
MADVAN
The E4 can only set a fault slip code while in OD.
You can have a slip in lower gears and no fault code.
The 4R can fault code in lower gears due to it has the input shaft sensor.
Bill
Old Feb 26, 2008 | 09:36 AM
shanett306's Avatar
shanett306
no od light flashing, cel is not on, fluid is at proper level and still looks clean.
It was slipping gin both od and 3rd the tranny was a ford reman before I bought the truck probably has about 30-40 thousand miles on it.
Old Feb 26, 2008 | 10:33 AM
fluidp's Avatar
fluidp
This sounds like what mine was doing. Was there any extra noise that came from the trany when it was slipping??
Old Feb 26, 2008 | 10:44 AM
shanett306's Avatar
shanett306
no there was no noise at all
I just wanna know how I can tell weather its the tranny or torque converter
Old Feb 26, 2008 | 10:58 AM
fluidp's Avatar
fluidp
I was talking to a GOOD FORD mechanic yesterday about my prob and he said that if the TC is slipping, you won't hear it.
Since I can hear mine howling when it slips he said it will be the trany. Hope this helps
Graham
