Hey guys. I am trying to get the trouble codes off of my '93 Ranger without having to buy a reader or a multi-meter. I read a post by Green 94 Ranger that he hooks up a wire to his negative battery terminal and the codes blink out on the dash. Can anyone please tell me how to do this with a little more detail? Like where the terminal is? I have been able to do this on many other makes of cars and trucks, I just don't know how to do it on this one. I have done quite a few searches trying to figure this out, and read the technical posts, but no luck.
Thanks in advance.
KP
I'm trying to find the info now, when I do I'll post a link to it here.
KP
Here is one I found, but there is a better one with pics showing how to do it, I am still looking for it. scroll down to bottom of page to see written explanation.
R
HERE IS THE LINK, COPY AND PASTE http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Reason: forgot to insert link
I retrieved some codes; do these seem like codes I could get get? 116 and 177. I get them both twice right in a row...116..116..177..177
It is weird, it seems like I am getting 116..116..1..177..177. What do I do with the extyra digit? I also assume the dull flicker in the beginning is not a flash as it is not as bright as the rest of the codes flashes?
Hey okay, I did pull the codes when the engine was cold, as was I and my freezing feet!! There is like over a foot of snow on the ground here and around 10 F.
What could cause the engine to be running rich on the one side of the engine other than that O2 sensor? It does seem like it could be running rich. It is hard to start and it feels like it is missing while I am driving it. I guess maybe it could be fouled plugs on that side? It sucks that I have to work on it outside in this freezing wheather, but I guess that I should be thankful that hopefully it is not anything too serious?
I was hoping that pulling the KOEO codes would tell me exactly what I should do to fix the prob! Do you guys think I should do the KOER test on it? I am just learning this OBD system, don't know if that would make a difference or not.
There are few things that will cause a rich or lean condition on only one bank. A bad injector on that side could do it, but I can't really think of anything else. That's why the 02 sensor is suspect.
How many miles on the truck, and when is the last time it was tuned up?
Hey, truck is running great now. I did all of the plugs and the O2 sensor on that side. Going to drive it around for awhile and check the codes again. The only other thing it does is that it doesn't start right up. It doesn't take super long, but longer than it should take to have the crank sensor go all of the way around.
Anyway,
Thanks a bunch. Maybe I will teach the guys at Autozone and Napa how to get the codes as they told me there was no way to do it without a special reader that they also didn't sell!
I disconnected briefly, how long do I need to disconnect it for? Arrgh, everything was running great but now my AC compressor seems to have frozen up somehow; if I get the shorter belt for the non AC 3.0 will I be able to just bypass the AC compressor? Need the truck for work!!
