2bbl. to 4 bbl?
Old Jan 11, 2009 | 12:45 PM
  #31
Franklin2's Avatar
Franklin2
Originally Posted by fordtruckf150
I have a 1986 ford f150. It came with and has in it a 2bbl carb. I want to switch it to a 4bbl carb. What intake manifold should I go with or could I even find one from a used truck and just put it on there or would I have to switch a couple of things as well as the intake manifold. I found a stock 351w intake manifold for $30. Just what else what I have to do or need?
What engine do you have? A 351w intake will only fit on a 351w. A 302 only on a 260/289/302.
As far as types of intakes, Ford made cast iron ones for the 289/302 from mid 60's to late 60's. They made cast iron ones for the 351w on and off up through the mid 80's.
If you get a aluminum one, make sure to stick with a dual plane intake. This will be the ones with 4 holes where the carb mounts, or ones that have the divider in the middle were the carb bolts.
Rusty_S
34
Jun 22, 2016 02:29 PM
Rusty_S
Jun 22, 2016 07:52 AM
axidjw
Feb 29, 2016 04:34 PM
chefcharles
Dec 9, 2014 12:11 PM
otis302
Mar 26, 2011 11:53 AM
