tranny oil
ffice
ffice" /><O
></O
>Anyway, I live in Port Perry Ontario and I just bought a 2005 F350. I tow a 10,000 boat and while the F150 was capable of towing a boat this size it was way over the max weight.
<O
></O
>My issue is that I picked the truck up on the weekend and once it was in the driveway I slid under to have a look. While it was at the dealership I had them change the transmission fluid. I noticed that one of the pan bolts was not tight. It was sticking out about 3 mm.
<O
></O
>- Is there a gasket between the pan and the casting or is it an RTV seal. If it is a gasket there would be no issue but if it is an RTV seal it would be a problem.
></O
>- How do you check the oil level? It is very difficult to see on the dipstick. It appears to have a light coating all over the stick. What should it look like?
The fluid level in the trans is hard to read. Using a clean white piece of paper helps. Set the wet dipstick on the paper and sometimes it easier to see the level that way.
