Anyone verify this before I dig into the fuel pump?
I bought all my parts for the fuel pump replacement project from the local Ford dealer. My question is, how big are the banjo bolt copper gaskets.
The ones they gave me are exactly 5/8" in diameter. The banjo bolt they are supposed to go over is almost 1" in diameter. Am I missing something , or will I just get it when I take the banjo bolt out?
thats sound about right. The banjo bolt is 1 1/4 wrench but about right for the shank of it.
here is the part number I have for the washers
Fuel Line Banjo Outlet Seals (seals banjo fitting of "wishbone" line)
(Ford) F4TZ-9A375-A
Well it does sound fishy. The banjo bolt is straight, no steps up or down. The seals contact right on the back of the pump so I guess if they don't match up they probably aren't right. Its has been over a year since I have had those parts in my hands.
I have changed out quite a few fuel pumps and only had one leak after reusing the old copper seals. That was my own fault, i had gotten some gunk from down in the valley up on the gaskets. They are not a bad idea, but i wouldnt consider them necessary.
Is your fuel pump leaking? I am finding fuel in the valley, but only below the fuel pump. are the gaskets you are replacing known to leak?
The gaskets dont normally ever leak....... There is a weap hole on the bottom side of the lift pump. Brake clean the valley out and dry with compressed air. Then with the engine running check for fuel leaks directly below the pump. On my application its not to hard to see b/c i have a rear engine cover similiar to a van. You may have to use a mirror to see the leak if you have a pickup.
I have had one gasket leak, but as i said above it was due to my own fault, i dropped the washer down in the valley and got lazy and didnt wipe it off.
No no no the parts dept pulled the wrong gaskets. As always....you are the man!
I wasn't concerned about having the wrong number just wanted to make sure it was right for future reference! Glad to hear you got it worked out before you needed the parts in a bad way.
Slow...tell him the trick to get the pump out so he does not drop the plunger into the crank case....
Its not totally necessary to use the TRICK. I dont do it and never had a problem yet. I have broke the aluminum housing off that sticks into the block and still havent dropped a plunger. I should probably buy a few lottery tickets!
I am not exactly sure on the trick, but i would say to take the fuel lines off and bump the motor off untill the lift pump. squirts fuel out of the pressure side of the pump. This will ensure that the camshaft lobe is in the up position and that the plunger does not have a chance to fall into the crankcase.
