Modular V10 (6.8l)
Sagging rear end
Old Feb 24, 2008 | 08:08 PM
bookum1's Avatar
bookum1
Sagging rear end
I pulled my first heavy load with my new to me 01 F250. I was pulling a 6000lb tractor on a 20' trailer. It pulled great, but the rear end sagged pretty bad. are there any add ons that can help?
Old Feb 24, 2008 | 09:10 PM
Monsta's Avatar
Monsta
Sit. Stay.
Maybe adjusting the trailer load will help.
If not, sounds like a weight distributing hitch is in order.
Old Feb 24, 2008 | 09:19 PM
highland61's Avatar
highland61
That is a pretty light load, your tongue weight wasn't right.
Either way, there are bags you can buy in addition to helper springs. Proper tongue weight, no matter if it is 2K or 12K pounds is more important than a saggy back side.
Old Feb 25, 2008 | 11:53 AM
69cj's Avatar
69cj
I pull an 11k 5ver with 1200 lb' pin weight with no sag. Check your distribution!
Old Feb 25, 2008 | 12:30 PM
dkf's Avatar
dkf
Firestone airbags work well and are inexpensive.
You can change the ride height quite a bit whether empty or loaded.
Try to put the load farther back on the trailer. I see tons of guys loading trailers with everything in front of the axles. You need adequate tonque weight but not too much.
96f150
1997 - 2003 F150
13
Dec 23, 2016 04:25 PM
annaleigh
Jul 26, 2015 08:04 PM
jle70
18
Jul 20, 2014 03:05 PM
jle70
Sep 26, 2008 01:00 PM
Mudder
Offroad & 4x4
Oct 25, 2004 12:15 AM
