Rear Coil Sag
Old Sep 21, 2008 | 06:35 PM
jle70's Avatar
jle70
Rear Coil Sag
My 01 Expy sags to the pass side a little. I think it would have to be coil spring.
Is there an aftermarket replacement? Checked Moogs site nothing found.
Old Sep 21, 2008 | 09:12 PM
heymrdj's Avatar
heymrdj
Do you have air suspension or regular? Saying coil I imagine you're talking about the front passenger side, not the rear?
Old Sep 22, 2008 | 07:07 AM
jle70's Avatar
jle70
Std suspension, and yes the rear coils.
Old Sep 22, 2008 | 09:03 AM
alloro's Avatar
alloro
It's possible that you might have to order the spring by using the spring code from the old spring. Sometimes the code is stamped into the spring and sometimes there is a tag on the spring. If you can find that code, then you can do a search using the code and maybe have better luck.
Of course there's always used parts.
Car-Part.com--Used Auto Parts Market
Old Sep 26, 2008 | 01:00 PM
ATLoffroad's Avatar
ATLoffroad
I would replace both sides. If you just replace the left side then the right side will look like it is sagging.
