Make your own diesel filter???
Now that I have your attention, I just have a quick question. We all know the way diesel has gone through the roof the last few days....well the WalMart here in Charleston didn't jack it up immediatly so I was able to go fill up 3 55 gallon cans and put them in the garage. I rigged up a Harbor Freight rotary pump with 1 inch clear plastic tubing for to pump it into the truck. I got to thinking about a filter between the pump and the valve on the end of the hose. I was thinking about fabricating some sort of PVC tube with the 1 inch barbed fittings on each end but what would you use for filter media inside? I looked around on Ebay for some diesel filters but they are mostely like the inline kind with the ITP In tank kits and I just want something simple to filter any stuff that might have gotten into the 55 gallon tank as I pump it into the truck. As a side note, the cans were cleaned out really well so I would say there is NOTHING in them and the 5 gallon cans were all clean, but I really don't want to take any chances. Any suggestions???? I could not turn down the chance at diesel for $3.16 a gallon when it jumped to $3.43 and $3.55 everywhere else in town....Man I hate saying that I was glad to jump on it for $3.16
Go by your local farm supply store or farm tractor dealer. They will have a large (about 1 qt) filter with a clear or red plastic housing and a water drain valve on the bottom for around $15-$20. This type of set up is exactly what they're made for.
You could also check places that sell auxiliary fuel tanks, or even a Northern Tool if you have one near you.
I've hot a lever pump style handle on the 55 ga. drum I use for my tractor with this set up. I'm not familiar with the rotary pump Harbor Freight sells, but I do know that some rotary pumps need to be primed before they work. If you have any problems with yours, unscrew the outlet tube off the top of the pump and pour some diesel down it to get the pump primed.
Thanks for the input.....the pump is self priming and pumps a 3/4 inch outlet tube with lots of volume and pressure with little effort. I was just looking for something to filter out the trash and moisture (if any) while it is waiting to be used. I looked at the northern tool online catalog and they had some clear water seperators so it should be just a matter of "rigging" up some fittings. I want to conserve what I have cause there is no telling what the price will be up to when I go to refill them if I can afford to even then...who knows what it will do for sure. I will check out the farm supply places and see what they might have. There is no Tractor supply place around here...just my luck that would probably have what I needed. I was just thinking about something like folks have used to filter the fumes from the CCV vent....I guess I just wanted to make something work from scratch. Thanks again, I will post what I come up with, and keep the suggestions coming...the light bulb will come on eventually...
That's good to know..
Originally Posted by randomhero1172
I had about Eight 55 gallon drums full of diesel that was about 1.5 years old I ran the same exact pump you did with no filter and never had a problem. Some drums sat in a warehouse for a 6-8 months as well. Never got a Water in fuel light or anything.
F350-6 had it right I used to keep a 500 gal above ground tank for fuel when I was farming and you can even get them with water seperating filters. Here is some different ones I used to use the golden rod 17041 water block setup on my outside tank the the standard on my inside tanks they are 10 micron which will get most of the stuff you have to worrry about and then the trucks filter can do the rest.
http://www.northerntool.com/webapp/w...6970_106+79097
Originally Posted by Kwikkordead
A filter that might suit your needs is for a diesel Jetta.
It has two 7mm (3/8") fittings on the top of the filter, one in and one out, with a water drain on the bottom.
Part number: 191 127 401C
I'll post a picture next post.
90pioneer
17
05-03-2011 09:18 PM
DaveWilliams
21
07-23-2007 09:34 PM
